StarTech.com Portable Server Rack - 9U
Quicklinx: BP74WS00 Mfr#: RK960CP
Depth (mm): 51.9cm
Width (mm): 60.4cm
£267.95 ex VAT
£321.54 inc VAT
Store your servers, network and telecommunications equipment in a portable, rolling server rack. This 9U portable server rack lets you store your server, network and telecommunications equipment in a sturdy mobile rack that has a fixed depth of 23 inches.
With built-in handles and four swiveling casters, this mobile rack is easy to transport around your server room, office or studio. Its increased mobility makes this cabinet the ideal solution for telecommunication racks that need to interface with different equipment around your workspace.
The server rack features heavy-gauge mounting rails to ensure a stable installation platform. This durable 4-post rack supports a static loading capacity of up to 220 lb (99.8 kg), and is compliant with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494), providing a universal design that's compatible with most rack equipment.
Save time and hassle with a rack that's easy to put together. With its easy four-step assembly process, you can set this portable rack up in minutes.
  • Portable design
  • Durable construction
  • Fast assembly
    Save time and hassle with a rack that's easy to put together. With its easy four-step assembly process, you can set this portable rack up in minutes. The RK960CP is backed by a 2-year StarTech.com warranty and free lifetime technical support.
StarTech.com 9U Open Frame Rack with Wheels - 4 Post 23" Deep Portable Open Frame Cabinet for 19" Network, Data & Server Equipment - 220 lbs capacity (RK960CP) - rack - 9U
Rack
Package Content
2 lockable casters, Phillips screwdriver, 2 casters, cage nut tool, 32 M5 screws, 24 M3 screws, Phillips bit, 16 M5 bracket screws, 30 M5 panel screws, 30 M5 cage nuts
Rack Size
23"
Height (Rack Units)
9U
Product Material
Steel
60.4 cm x 51.9 cm x 48.33 cm
27.2 kg
4 post rack mountable
Rack
Product Material
Steel
Package Content
Rack Size
23"
Height (Rack Units)
9U
60.4 cm
51.9 cm
48.33 cm
27.2 kg
Inner Dimensions
45 cm x 41.73 cm
Weight Limit
544 kg
Mounting Kit
Included
Wheels Qty
4
Limited warranty: - 2 years
BP74 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
BP74 StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £45.84
BP74 StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £79.45
BP74 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
BP74 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
BP74 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £30.71
BP74 StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £351.41
BP74 StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £8.24
BP74 StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £11.53
BP74 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.44
BP74 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
BP74 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
BP74 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
BP74 StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.33
BP74 StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
BP74 StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.20
BP74 StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £543.36
BP74 StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.88
BP74 StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £102.81
BP74 StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £62.88
BP74 StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £72.65
BP74 StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
BP74 StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £56.70
BP74 StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.28
BP74 StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.00
BP74 StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £51.38
BP74 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
BP74 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.24
BP74 StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
BP74 StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
BP74 StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
BP74 StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.48
BP74 StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.11
BP74 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
BP74 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
BP74 StarTech.com 25U 36in Server Rack Cabinet In Stock £730.55
BP74 StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
BP74 StarTech.com 100 Pkg M5 Cage Nuts In Stock £30.81
BP74 StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
BP74 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
BP74 StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
BP74 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
BP74 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
BP74 StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters In Stock £514.25
BP74 Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
BP74 StarTech.com 19in Cable Management Panel In Stock £24.18
BP74 StarTech.com Vented 1U Rack Shelf - 10in In Stock £21.05
BP74 StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
Depth (mm): 51.9cm
Width (mm): 60.4cm
