The BLANKB2 2U Blank Panel is designed to EIA RS-310-C specifications and fits all 19" standard server racks and cabinets. The filler panel/blank panel is constructed of cold rolled steel and features a black powder coated finish that matches most industry standard black server cabinets and racks.
 - StarTech.com 2U Blanking Panel - Steel Rack Mount Filler Panel - for 19in Server Rack Enclosure or Cabinet - Black Rack Panel (BLANKB2) - blank panel - 2U
- Product Type
 - Blank panel
 - Black
- Rack Size
 - 19"
- Height (Rack Units)
 - 2U
- Product Material
 - Cold-rolled steel
 - 48.3 cm x 1.3 cm x 8.8 cm
 - 0.52 kg
 - Limited lifetime warranty
- Designed For
 - P/N: RK1236BKF, RK2536BKF, RK4236BKB, RK619WALL, RK619WALLGB, RK960CP
- Product Type
 - Blank panel
- Product Material
 - Cold-rolled steel
- Rack Size
 - 19"
 - 2U
 - 48.3 cm
 - 1.3 cm
 - 8.8 cm
 - 0.52 kg
 - Black
 - RoHS
 - Limited warranty: - lifetime
- Designed For
                        StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg | In Stock | £92.31 |
                        StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails | In Stock | £76.74 |
                        StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £11.90 |
                        StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £30.44 |
                        StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £8.29 |
                        StarTech.com 2U Rack Blank Panel for 19in Server Racks and Cabinets | In Stock | £11.48 |
                        StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets | In Stock | £97.41 |
                        StarTech.com 19in Cable Management Panel | In Stock | £23.58 |
