Quicklinx: BT5BWS00 Mfr#: CABCAGENUTSB
Product Type: Cage nuts
£5.39 ex VAT
£6.46 inc VAT
Install your rack-mountable hardware securely with these high-quality cage nuts. This 50-pack of M5 cage nuts is convenient to have on hand for installing rack-mountable equipment, such as your server, network or audio/video equipment.
The bulk pack is also suitable for new server rack and cabinet setups - perfect for those times when you drop or misplace a nut or two. The bulk package ensures that you have enough cage nuts available for all of your installations, when you need them.
The server rack cage nuts come in an all-black finish for a seamless look.
StarTech.com M5 Cage Nuts - 50 Pack, Black - M5 Mounting Cage Nuts for Server Rack & Cabinet (CABCAGENUTSB) - cage nuts
Cage nuts
Packaged Quantity
50 (specifications are for single item)
Product Material
Steel
P/N: RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK2537BKM, RK2620WALHM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK519WALLV, RK616WALM, RK920WALM, RK9WALM, RKQMCAB12V2, WALLMOUNT4
Packaged Quantity
Cage nuts
Product Material
Steel
Limited warranty: - 2 years
P/N: 2636CABINET, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CAB1019WALL, RACK-18U-20-WALL-OA, RACK-21U-20-WALL-OA, RACK-24U-20-WALL-OA, RK119WALLV, RK1219SIDEM, RK1219WALH, RK1219WALHM, RK1219WALL, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK219WALLV, RK219WALVO, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK319WALLV, RK3236BKF, RK419WALLV, RK419WALVO, RK419WALVS, RK419WALVSGB, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK519WALLV, RK616WALM, RK619WALL, RK619WALLGB, RK619WALLOH, RK619WALLV, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK8OD, RK920WALM, RK960CP, RK9WALM, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, WALLMNT12, WALLMOUNT4, WALLMOUNT6, WALLMOUNT8, WALLMOUNTH1, WALLMOUNTH2, WALLMOUNTH4
BT5B StarTech.com 42U Adjustable Depth Open Frame 4 Post Server Rack Cabinet - Casters Levelers and Hooks In Stock £208.39
BT5B StarTech.com 25U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £197.30
BT5B StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks In Stock £169.35
BT5B StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
BT5B StarTech.com 2-Post Server Rack - 42U In Stock £147.91
