This 8U Open Frame Wall Mount Equipment Rack is a high quality, low cost relay rack that is easy to assemble and install into any environment. The rack can be wallmounted or installed as a free standing storage solution.
Able to accommodate common data, audio-video and telecom equipment, the open rack offers a depth of 12in; the wall mounts are positioned 16in apart (center to center), making it suitable for mounting on virtually any wall surface, based on North American wall frame stud spacing standards.
- StarTech.com 8U 19" Wall Mount Network Rack - 12" Deep 2 Post Open Frame Server Room Rack for Data/AV/IT/Computer Equipment/Patch Panel with Cage Nuts & Screws 135lb Capacity, Black (RK812WALLO) - rack - 8U
- Product Type
- Rack
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 8U
- Product Material
- Steel
- 50.5 cm x 30.8 cm x 35.6 cm
- 8 kg
- Designed For
- P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224
- Product Type
- Rack
- Product Material
- Steel
- Rack Size
- 19"
- 8U
- 50.5 cm
- 30.8 cm
- 35.6 cm
- 8 kg
- Black
- Weight Limit
- 80 kg
- UL, RoHS
- Limited warranty: - 1 year
- Designed For
StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep | In Stock | £66.84 |
StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet | In Stock | £44.03 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £11.90 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £29.91 |
StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel | In Stock | £48.26 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.39 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £27.99 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £52.23 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £55.25 |
StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth | In Stock | £129.80 |
StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters | In Stock | £353.02 |
StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel | In Stock | £31.67 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) | In Stock | £3.06 |
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) | In Stock | £4.23 |
StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel | In Stock | £37.64 |
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel | In Stock | £46.00 |
StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £17.41 |
StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover | In Stock | £22.90 |
StarTech.com 100 Pkg M6 Screws & Cage Nuts | In Stock | £55.20 |
StarTech.com 50 Pkg M6 Screws & Cage Nuts | In Stock | £29.89 |
StarTech.com Portable Server Rack - 9U | In Stock | £261.41 |
StarTech.com 25U 36in Server Rack Cabinet | In Stock | £712.74 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £25.96 |
StarTech.com 50 Pkg M6 Cage Nuts | In Stock | £19.69 |
StarTech.com 100 Pkg M5 Cage Nuts | In Stock | £29.98 |
StarTech.com 50 Pkg M5 Cage Nuts | In Stock | £15.03 |
StarTech.com 100 Pkg M5 Screws & Cage Nuts | In Stock | £52.24 |
StarTech.com 50 Pkg M5 Screws & Cage Nuts | In Stock | £27.56 |
StarTech.com 50 Pkg M5 Mounting Screws | In Stock | £15.48 |
StarTech.com 100 Pkg M5 Mounting Screws | In Stock | £28.96 |
StarTech.com 50 Pkg M6 Mounting Screws | In Stock | £16.16 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £26.90 |
StarTech.com 100 Pkg M6 Cage Nuts | In Stock | £27.56 |
StarTech.com 22U 36" Knock-Down Server Rack Cabinet with Casters | In Stock | £501.70 |
StarTech.com 19in Cable Management Panel | In Stock | £23.58 |
StarTech.com 18U Server Rack Enclosure | In Stock | £369.77 |
StarTech.com 6U Wall-Mount Rack Cabinet | In Stock | £148.99 |
StarTech.com 26U Server Rack Enclosure | In Stock | £463.46 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £174.53 |
StarTech.com 9U Wall-Mount Rack Cabinet | In Stock | £193.99 |
StarTech.com 12U Server Rack Enclosure | In Stock | £330.35 |
StarTech.com 12U Server Rack Enclosure | In Stock | £280.72 |
StarTech.com 15U Server Rack Enclosure | In Stock | £313.10 |
StarTech.com 12U Server Rack Enclosure | In Stock | £375.79 |
StarTech.com 10-32 Server Rack Screws and Nuts - 50 Pack - Black - TAA Co | In Stock | £28.33 |
StarTech.com M6 Mounting Screws 50Pack | In Stock | £16.79 |
StarTech.com 42U Server Rack Cabinet | In Stock | £1,227.89 |
