StarTech.com 5 Port Unmanaged Energy-Efficient Gigabit Ethernet Switch
Quicklinx: 9KRKWS00 Mfr#: DS51002GB
The DS51002 5-port unmanaged Gigabit Ethernet switch lets you network up to 5 Ethernet devices through an energy-efficient gigabit switch, designed for desktop or wallmount installations.
Compatible with 10/100/1000 Mbps networks, this 5 port switch supports full/half-duplex auto-negotiation, jumbo frames and auto MDI/MDIX operation, allowing you to connect your network devices quickly and easily with little to no configuration required.
This unmanaged switch supports the IEEE 802.3az energy-efficient Ethernet standard, which offers power-saving features without compromising performance. The switch can automatically power down ports without a link, budget power output based on cable lengths and can also reduce the power consumption in idle or low-traffic modes.
StarTech.com 5 Port Unmanaged Energy-Efficient Gigabit Ethernet Desktop / Wall Mount Network Switch - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Forwarding performance (full duplex): 2 Gbps
Jumbo Frame Support
16KB
Auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
AC 120/230 V
18 cm x 12 cm x 3.01 cm
215 g
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
Performance
Jumbo Frame Support
16KB
Status Indicators
Power, link/activity
5 x 1000Base-T RJ-45
External power adapter
AC 120/230 V
FCC, RoHS
18 cm
12 cm
3.01 cm
215 g
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
