This 2-port USB-C KVM enables you to easily switch between two USB Type-C or Thunderbolt 3 desktop or laptop computers, using a single keyboard, HDMI monitor and mouse.
Easy to setup and use
Utilizing USB-C with DP alt-mode, this compact KVM switch only requires a single cable be connected to each of your computers, ensuring a small footprint with limited cabling requirements. All required cables for connecting your computers are included, to ensure a hassle-free setup right out of the box. For easy operation, the KVM features a single button that toggles between connected computers. -
Supports high resolutions
The USB-C KVM switch supports high resolutions and can drive one large HDMI 2.0 display with ease, maximizing viewing space. -
Compact and portable
Along with the USB-C design that ensures cabling requires are minimum the KVM is bus powered further reducing clutter by avoiding the need for a bulky power adapter. The lightweight small form factor makes this mini KVM switch easy to deploy and is ideal for mobile/hot desk workforces.
- StarTech.com 2 Port USB C KVM Switch, 4K 60Hz HDMI, Compact Dual Port UHD USB Type C Desktop Mini KVM Switch with USB C Cables, Bus Powered, MacBook iPad Pro ThinkPad IdeaPad EliteBook - 4K HDMI KVM Switch - KVM / audio switch - 2 ports
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- USB powered, 7.1 channel audio support
- 14 cm x 7.2 cm x 1.6 cm
- 265 g
- Black
- 2-year warranty
- Enclosure Type
- Desktop
- Subtype
- KVM
- Ports
- 2 x KVM / audio
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 3840 x 2160 @ 60 Hz
- Status Indicators
- Port status
- 2 x USB-C , 1 x HDMI output , 2 x USB 2.0 input Type A console
- Black
- Cables Included
- 2 x USB-C cable - 1 m
- MTBF
- 50,000 hours
- RoHS, WEEE, REACH, DisplayPort 1.2
- 14 cm
- 7.2 cm
- 1.6 cm
- 265 g
- Shipping Width
- 17.2 cm
- Shipping Depth
- 12 cm
- Shipping Height
- 8.5 cm
- Shipping Weight
- 600 g
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 50 °C
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £8.48 |
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 | In Stock | £22.45 |
StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops | In Stock | £15.51 |
StarTech.com HDMI to DisplayPort Converter - 4K | In Stock | £36.91 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £12.99 |
StarTech.com 2m USB 3.0 C Cable w/ PD (3A) | In Stock | £14.27 |
StarTech.com 1m USB 3.1 C Cable w/ PD (5A) | In Stock | £25.86 |
StarTech.com 1m USB C Cable - USB 3.0 | In Stock | £11.01 |
StarTech.com 0.5m USB C Cable - USB 3.1 | In Stock | £12.76 |
StarTech.com 1.8m USB 3.1 5Gbps with PD (5A) C to C Cable - M/M Certified | In Stock | £26.07 |
StarTech.com 2 Port Hybrid USB-C KVM Switch | In Stock | £32.88 |
StarTech.com USB-C KVM Switch, 4K 60Hz | In Stock | £150.27 |
