StarTech.com 3.5in Silicone Hard Drive Protector Sleeve with Connector Cap
Quicklinx: 6B9HWS00 Mfr#: HDDSLEV35
Select:
This two piece silicon hard drive protector sleeve provides a layer of sturdy protection against potential shock/impact damage for your 3.5 in hard drives. When enclosed with larger top portion of sleeve, they provide added stability and protection for 3.5 in.
This stackable versatile hard drive sleeve also offers the flexibility to fit most uninstalled IDE and SATA/SAS 3.5 in HDDs, featuring a tip cover that's specifically designed to protect the hard drive interface ports during transportation or stacking, but can be removed for installation.
The hard drive protector features a durable silicon design and a ventilation hole in the top portion for enhanced heat dissipation.
The HDDSLEV35 is the perfect accessory to the SATA hard drive docks and "bare drive" (trayless) hard drive enclosures, and for keeping unused drives safe while not in use.
StarTech.com 3.5in Silicone Hard Drive Protector Sleeve with Connector Cap - Protective Sleeve Case for 3.5 HDD (HDDSLEV35) - hard drive protective sleeve
Hard drive protective sleeve
Product Material
Silicone
12 cm x 15.5 cm x 3.2 cm
91 g
Clear
1-year warranty
P/N: S351BMU33ET, S351BMU33ETG, SATDOCK5U3ER, SATDUP11IMG, SATERASER4, SATSASDUPE11, SDOCK1EU3P, SDOCK1EU3P2, SDOCK2ERU33, SDOCK2U313R, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCK4U313, SDOCK4U33, SDOCKU313, SDOCKU313E, SDOCKU33BV, SDOCKU33EBV, SDOCKU33EF, SU2DUPERA11, UNIDOCKU33
Product Material
Silicone
12 cm
15.5 cm
3.2 cm
91 g
Clear
RoHS
Limited warranty - 1 year
P/N: S351BMU33ET, S351BMU33ETG, SATDOCK2REU3, SATDOCK4U3RE, SATDOCK5U3ER, SATDOCKU3S, SATDUP11, SATDUP11IMG, SATERASER4, SATSASDUPE11, SDOCK1EU3P, SDOCK1EU3P2, SDOCK2ERU33, SDOCK2U313R, SDOCK2U33, SDOCK2U33EB, SDOCK2U33RE, SDOCK2U33V, SDOCK4U313, SDOCK4U33, SDOCKU313, SDOCKU313E, SDOCKU33BV, SDOCKU33EBV, SDOCKU33EF, SDOCKU33HW, SU2DUPERA11, UNIDOCKU33
6B9H StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.56
