StarTech.com 4 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III
Quicklinx: 9XDCWS00 Mfr#: HSB4SATSASBA
Type: Storage mobile rack
HD Size: 2.5
Power Supply: [N/A]
12 In Stock
£84.20 ex VAT
£101.04 inc VAT
Connect and hot swap four 3.5in SATA III or SAS II hard drives to your computer system in three 5.25" bays, with support for transfer speeds up to 6 Gbps. The HSB4SATSASBA Removable 4-drive Backplane makes inserting and removing drives fast and easy, by turning three 5.25" bays into a hot-swappable interface for up to four 3.5" SATA or SAS hard drives (HDD).
For added versatility, the hot swap bay can interface with SATA I/II/III and SAS I/II hard drives - an ideal solution for enterprise system applications.
For a quick and secure method of installing and removing drives, the backplane features ejection levers and a key-lock design. To help prevent drive failure, the bay provides drive cooling with a built-in fan and excellent heat dissipation with a vented aluminum enclosure.
  • Efficient hot-swap design
    The mobile rack allows for quick and easy replacement of hard drives without the need for system shutdown, increasing overall productivity.
  • Real-time indicators
    Equipped with data and power indicators, users can monitor the status of their drives for efficient management and troubleshooting.
  • Robust cooling system
    The integrated cooling fan ensures that hard drives operate within the safe temperature range, preventing overheating and extending their lifespan.
  • High-speed connectivity
    Supports Serial ATA-600 for rapid data transfer, making it suitable for demanding applications and data management tasks.
  • Versatile compatibility
    Compatible with both SAS II and SATA III drives, as well as various hard drive form factors, offering flexibility for different storage needs.
StarTech.com 4-Bay Mobile Rack Backplane - Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III - 6 Gbps HDD (HSB4SATSASBA) - storage mobile rack
Storage mobile rack
Expansion Bays
4 x hot-swap - 3.5"
Compatible Bay
3 5.25"
Hard Drive Form Factor Compatibility
2.5"
Supported Interface
SATA-600
Drive Connector
29 pin internal SAS (SFF-8482)
Data indicator, power indicator, cooling fan
Product Material
Aluminium
14.5 cm x 19.8 cm x 12.5 cm
120 g
Storage mobile rack
2.5"
Product Material
Aluminium
Supported Interface
SATA-600
Storage Controller
No CPU
Bays
4 x hot-swap - 3.5"
4 x SATA 6Gb/s - 29 pin internal SAS (SFF-8482)
4 - 7 pin Serial ATA , 2 - 15 pin Serial ATA power
Compatible Bay
3 x external 5.25"
2 security keys, 8 x screws
4 x Serial ATA cable
FCC, RoHS
14.5 cm
19.8 cm
12.5 cm
120 g
55 °C
5 - 85%
9XDC StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
9XDC StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.48
9XDC StarTech.com 12in Latching SATA Cable In Stock £6.16
9XDC StarTech.com 18in Latching SATA Cable In Stock £4.24
9XDC StarTech.com 24in Latching SATA Cable In Stock £6.84
9XDC StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive In Stock £17.75
9XDC StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane In Stock £44.84
9XDC StarTech.com 6in 4 Pin Molex to Right Angle SATA Power Cable Adapter In Stock £5.05
9XDC StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £5.44
9XDC StarTech.com 12in LP4 to 2x Latching SATA Power Y Cable Splitter Adapter - 4 Pin Molex to Dual SATA In Stock £5.50
9XDC StarTech.com 6in Latching SATA Power Y Splitter Cable Adapter - M/F In Stock £5.60
9XDC StarTech.com 4 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £84.20
9XDC StarTech.com 18in Right Angle SATA Cable In Stock £4.34
HD Size: 2.5
Power Supply: [N/A]
