StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket
Quicklinx: 92P6WS00 Mfr#: BRACKET25X2
£7.24 ex VAT
£8.68 inc VAT
Mount two 2.5in SATA SSDs/HDDs into a single 3.5in drive bay. The BRACKET25X2 Dual hard drive mounting bracket kit enables you to maximize the internal mounting space of your computer, by installing two 2.5in SATA hard drives (HDD) or solid state drives (SSD) into a single 3.5in mounting bay. The bracket can be used with IDE drives using the 2.5in to 3.5in IDE Hard Drive cable adapter (IDE4044).
For a hassle-free installation, the hard drive mounting kit includes all required data and power cabling for both SATA drives.
The BRACKET25X2 features solid steel construction.
  • Compact design
    This mounting bracket kit allows the installation of two 2.5" drives into a single 3.5" bay, saving space and maximizing storage efficiency.
  • Efficient cable management
    Includes Serial ATA cables and a power Y cable, ensuring a tidy setup while providing all necessary connections for immediate use.
StarTech.com 2.5" to 3.5" SATA Hard Drive Mounting Bracket Kit - Dual SATA SSDs/HDDs Mounting Bracket for Mounting Bay (BRACKET25X2) - storage bay adapter
Storage bay adapter
Steel
Supported Form Factor
3.5" to 2.5"
Expansion Bays
2 x internal - 2.5"
Compatible Bay
1 3.5"
10.2 cm x 11.6 cm x 2.2 cm
150 g
P/N: 25S22M2NGFFR, 25SAT22MSAT, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, ST521PMINT
Storage bay adapter
3.5" to 2.5"
Steel
Storage Controller
No CPU
Bays
2 x internal - 2.5"
Compatible Bay
1 x internal 3.5"
1 x Serial ATA power Y cable , 1 x Serial ATA cable
RoHS
Limited warranty - lifetime
10.2 cm
11.6 cm
2.2 cm
150 g
92P6 StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £5.06
92P6 StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay In Stock £3.02
92P6 StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter In Stock £4.48
92P6 StarTech.com 12in Latching SATA Cable In Stock £6.16
92P6 StarTech.com 24in Latching SATA Cable In Stock £6.84
92P6 StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £5.44
92P6 StarTech.com 4x SATA Power Splitter Adapter Cable In Stock £6.60
92P6 StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket In Stock £7.24
92P6 StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm In Stock £20.49
92P6 StarTech.com 2.5" SSD/HDD Mounting Bracket In Stock £4.64
92P6 StarTech.com 2.5 to 3.5 Hard Drive Adapter In Stock £23.17
92P6 StarTech.com 18in Right Angle SATA Cable In Stock £4.34
Type: Storage bay adapter
