Turn a 2.5" SATA HDD/SSD into a 3.5" SATA Drive. The 25SAT35HDD 2.5" to 3.5" hard drive adapter enclosure turns a 2.5" SATA hard drive (HDD) or solid state drive (SSD) into a 3.5" drive.
The adapter enclosure lets you substitute a 3.5" hard drive for a 2.5" SSD/HDD in any application that would typically require a 3.5" drive, such as desktop chassis, backplane, or docking station. The enclosure has the same dimensions as a standard 3.5" hard drive, including mounting points, and SATA connector locations.
With support for drives up to 12.5mm in height, and high-capacity SATA I/II/III drives (tested up to 1TB) this HDD adapter ensures compatibility with virtually any 2.5" SATA hard drive or solid state drive.
Seamless compatibility
Designed to bridge the gap between 2.5" and 3.5" drive sizes, the StarTech.com SATA HDD/SSD Adapter Enclosure ensures seamless compatibility with both PC and Mac systems. This flexibility makes it an ideal solution for diverse computing environments. -
High-speed performance
With support for SATA 6Gb/s interface, this external hard drive converter facilitates data transfer rates up to 6 Gbit/s, enabling swift and efficient file transfers and backups. -
Durable construction
Crafted from a combination of aluminum and plastic, the enclosure is built for durability. Its robust construction not only protects your hard drive but also ensures longevity of the device. -
Optimized for enhanced reliability
The adapter enclosure is tested with up to 1TB 7200 RPM 2.5" hard drives, demonstrating its capability to handle high-performance drives reliably for extended periods.
- StarTech.com 2.5" to 3.5" SATA HDD/SSD Adapter Enclosure - External Hard Drive Converter with HDD/SSD Height up to 12.5mm (25SAT35HDD) - storage enclosure - SATA 6Gb/s - SATA 6Gb/s
- Storage enclosure - internal
- Bus Type
- SATA 6Gb/s
- Expansion Bays
- 1 x internal - 2.5" x 1/8H
- Compatible Bay
- 1 3.5" x 1/3H
- Hard Drive Form Factor Compatibility
- 2.5"
- Supported Interface
- SATA-600
- Drive Connector
- 22 pin Serial ATA
- Bay Connector
- 22 pin Serial ATA
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Product Material
- Plastic, aluminium
- 10.2 cm x 14.6 cm x 3.6 cm
- 260 g
- 2-year warranty
- Designed For
- P/N: S352BU33HR
- 2.5"
- Host Bus
- SATA 6Gb/s
- Product Material
- SATA-600
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Bays
- 1 x SATA 6Gb/s
- Connections
- 1 - 22 pin Serial ATA
- Compatible Bay
- 1 x internal 3.5" x 1/3H
- Cables Included
- 1 x Serial ATA cable
- Tested with up to 1TB 7200 RPM 2.5" hard drives
- FCC, RoHS
- Limited warranty - 2 years
- 10.2 cm
- 14.6 cm
- 3.6 cm
- 260 g
- Shipping Width
- 11.5 cm
- Shipping Depth
- 16.3 cm
- Shipping Height
- 3.8 cm
- Shipping Weight
- 260 g
- 5 °C
- 55 °C
- 5 - 85%
- Designed For
- P/N: S352BU33HR
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm
