Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and a standard DP monitor. The MDP2DPMM2M 2m Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DP male connector on one end, and a DP male connector on the other, allowing you to connect any Mini DisplayPort-equipped laptop (including the Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
The mDP to DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DP to DP Cables can be connected to the Thunderbolt ports, enabling you to connect your DP compatible displays.
Reliable connectivity
The Mini DisplayPort to DisplayPort cable features male connectors on both ends, allowing seamless connections between your Mac and DisplayPort displays for optimal performance. -
Excellent durability
Constructed with double shielded technology, the cable features aluminum mylar foil and braid shielding that protects against electromagnetic interference, promoting consistent and high-quality signal transfer. -
Secure latch design
This cable incorporates a latched design on the connectors, preventing accidental disconnections and providing peace of mind during use, especially in crowded setups or dynamic environments. -
High-quality construction
The connectors are nickel-plated to enhance longevity and resist corrosion, ensuring that the cable remains functional over time, even with regular use. -
Easy compatibility
Designed specifically for Mac systems, this cable allows straightforward Plug-and-Play connectivity, making it an appropriate choice for users seeking efficient and effective solutions.
- StarTech.com 2m Mini DisplayPort to DisplayPort 1.2 Cable DisplayPort 4k - DisplayPort cable - 2 m
- DisplayPort cable
- Technology
- Double shielded
- Latched
- Length
- 2 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- DisplayPort - male
- RoHS
- Black
- Limited lifetime warranty
- DisplayPort cable
- Technology
- Double shielded
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 32
- Plated Connector
- Nickel
- Latched
- Length
- 2 m
- Black
- Connector
- 20 pin DisplayPort - male
- RoHS
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £8.45 |
StarTech.com 1m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £3.73 |
StarTech.com 2m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £10.83 |
StarTech.com 1m Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £13.09 |
StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M | In Stock | £19.68 |
StarTech.com 3m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £13.38 |
