StarTech.com 3m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k
Quicklinx: 9FSVWS00 Mfr#: MDP2DPMM3M
Length: 3m
10 In Stock
£12.92 ex VAT
£15.50 inc VAT
Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and a standard DP monitor. The MDP2DPMM3M 3m Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DP male connector on one end, and a DP male connector on the other, allowing you to connect any Mini DisplayPort-equipped laptop (including the Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
The mDP to DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DP to DP Cables can be connected to the Thunderbolt ports, enabling you to connect your DP compatible displays.
  • High-quality connectivity
    Experience reliable and high-quality connectivity with the StarTech.com 3m Mini DisplayPort to DisplayPort 1.2 Cable, featuring gold-plated connectors for optimal signal transfer and corrosion resistance.
  • Enhanced viewing experience
    Designed to support DisplayPort 4k, this cable ensures you enjoy vibrant visuals and flawless audio, making it perfect for high-resolution gaming, streaming, or professional design work.
  • Durable design
    Constructed with an aluminum mylar foil shielding and a robust 32 AWG wire, this cable is built to withstand the rigors of daily use while ensuring consistent performance.
StarTech.com 3m Mini DisplayPort to DisplayPort 1.2 Cable DisplayPort 4k - DisplayPort cable - 3 m
DisplayPort cable
Shielded
Length
3 m
Connector
DisplayPort - male
Connector (Second End)
Mini DisplayPort - male
RoHS
DisplayPort cable
Shielded
Shielding Material
Aluminum mylar foil
American Wire Gauge (AWG)
32
Plated Connector
Gold
Length
3 m
Connector
20 pin DisplayPort - male
RoHS
9FSV StarTech.com 1m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.69
9FSV StarTech.com 2m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £10.45
9FSV StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M In Stock £19.20
Length: 3m
