StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F
Quicklinx: 76LPWS00 Mfr#: DP2MDPMF6IN
Type: DisplayPort
Length: 15.2cm
£8.60 ex VAT
£10.32 inc VAT
The DP2MDPMF6IN DisplayPort to Mini DisplayPort Adapter turns a mini DisplayPort (male) connector into a regular DisplayPort (male) connector, making it easy to connect a mini DisplayPort-equipped monitor to a laptop that only provides a standard DisplayPort output (e.g. Apple, Toshiba etc.).
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter (DP2MDPMF6IN) - DisplayPort adapter - 15.2 cm
DisplayPort adapter
Molded
Length
15.2 cm
Connector
DisplayPort - male
Connector (Second End)
Mini DisplayPort - female
RoHS
P/N: SV231DPU, SV231DPUA
DisplayPort adapter
Shielding Material
PVC
American Wire Gauge (AWG)
32
Molded
Length
15.2 cm
Connector
20 pin DisplayPort - male
DisplayPort 1.2, RoHS
76LP StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.15
76LP StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £11.19
76LP StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M In Stock £22.37
76LP StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £21.94
76LP StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.27
76LP StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £10.75
76LP StarTech.com Mini DisplayPort to VGA Video Adapter Converter In Stock £14.70
76LP StarTech.com Mini DisplayPort to HDMI Video Adapter Converter In Stock £11.24
76LP StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £14.07
76LP StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £8.60
76LP StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £11.66
76LP StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £14.83
76LP StarTech.com 2m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £11.02
76LP StarTech.com 1m Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £13.74
76LP StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.32
76LP StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £12.11
Type: DisplayPort
Length: 15.2cm
