StarTech.com 2m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k
Quicklinx: 7RX0WS00 Mfr#: MDP2DPMM2M
Length: 2m
36 In Stock
£10.22 ex VAT
£12.26 inc VAT
Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and a standard DP monitor. The MDP2DPMM2M 2m Mini DisplayPort to DisplayPort Adapter Cable, features a Mini DP male connector on one end, and a DP male connector on the other, allowing you to connect any Mini DisplayPort-equipped laptop (including the Mac family of products) to an HDTV, monitor or projector that uses a standard DisplayPort connection.
The mDP to DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DP to DP Cables can be connected to the Thunderbolt ports, enabling you to connect your DP compatible displays.
  • Reliable connectivity
    The Mini DisplayPort to DisplayPort cable features male connectors on both ends, allowing seamless connections between your Mac and DisplayPort displays for optimal performance.
  • Excellent durability
    Constructed with double shielded technology, the cable features aluminum mylar foil and braid shielding that protects against electromagnetic interference, promoting consistent and high-quality signal transfer.
  • Secure latch design
    This cable incorporates a latched design on the connectors, preventing accidental disconnections and providing peace of mind during use, especially in crowded setups or dynamic environments.
  • High-quality construction
    The connectors are nickel-plated to enhance longevity and resist corrosion, ensuring that the cable remains functional over time, even with regular use.
  • Easy compatibility
    Designed specifically for Mac systems, this cable allows straightforward Plug-and-Play connectivity, making it an appropriate choice for users seeking efficient and effective solutions.
StarTech 2m Mini DisplayPort to DisplayPort 1.2 Cable DisplayPort 4k - DisplayPort cable - 2 m
DisplayPort cable
Double shielded
Latched
Cable Length
2 m
Connector
Mini DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
DisplayPort cable
Double shielded
Shielding Material
American Wire Gauge (AWG)
32
Plated Connector
Nickel
Latched
Cable Length
2 m
Connector
20 pin DisplayPort - male
RoHS
7RX0 StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £8.02
7RX0 StarTech.com 1m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £3.64
7RX0 StarTech.com 2m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £10.22
7RX0 StarTech.com 1m Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £13.09
7RX0 StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M In Stock £19.68
7RX0 StarTech.com 3m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £12.63
Length: 2m
