StarTech.com 1m USB 2.0 USB-C to USB-A Cable
Quicklinx: BN49WS00 Mfr#: USB2AC1M
Length: 1m
19 In Stock
£10.31 ex VAT
£12.37 inc VAT
Connect your USB Type-C devices to your laptop or desktop computer. Need to connect your new USB-C mobile device to a computer with a traditional-style USB-A USB port? This 1m USB 2.0 USB-A to USB-C cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
Connect your newer mobile devices that feature a USB-C connector, such as the Nokia N1 tablet to your computer, with data transfer speeds of 480 Mbps.
The USB Type-C connector is smaller and easier to use than previous USB connectors. With a reversible design, you can plug it into your devices with either side facing up. Insert the cable the right way every time - no more frustration or port damage.
  • Charge and sync your USB Type-C mobile devices
    Connect your newer mobile devices that feature a USB-C connector, such as the Samsung Galaxy S8, S8+, Nexus 6P, and 5X phones to your computer, with data transfer speeds of 480 Mbps.
  • Connect with ease
    The USB Type-C connector is smaller and easier to use than previous USB connectors. With a reversible design, you can plug it into your devices with either side facing up. Insert the cable the right way every time - no more frustration or port damage. The USB2AC1M from StarTech.com is backed by a lifetime warranty for guaranteed reliability.
StarTech.com USB C to USB Cable - 3 ft / 1m - USB A to C - USB 2.0 Cable - USB Adapter Cable - USB Type C - USB-C Cable (USB2AC1M) - USB-C cable - 24 pin USB-C to USB - 1 m
USB-C cable
Double shielded
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
P/N: HB30A3A1CFB, HB30A3A1CSFS, HB30C1A1CPD, HB30C3A1CFB, HB30C3A1CFBW, HB30C3A1CFS, HB30C3A1GE, HB30C3A1GEA, HB30C3AGEPD, HB30C3APD, HB30C3APDW, HB30C4AB, HB30C4ABW, HB30C4AFPD, HB30C4AFS, ST4200MINIC
USB-C cable
Double shielded
Plated Connector
Nickel
Length
1 m
Connector
24 pin USB-C - male
USB / USB 2.0, RoHS
BN49 StarTech.com 1m USB 2.0 C to Micro-USB Cable In Stock £7.73
BN49 StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
BN49 StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.59
BN49 StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £10.24
BN49 StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.21
BN49 StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £10.31
BN49 StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £9.97
BN49 StarTech.com USB 3.0 USB-C to USB-A Adapter In Stock £8.24
BN49 StarTech.com USB-C to Micro-USB Adapter M/F In Stock £4.59
BN49 StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.87
BN49 StarTech.com 0.5m USB 2.0 C to A Cable M/M In Stock £7.94
BN49 StarTech.com 1m USB A to C Cable - USB 2.0 In Stock £9.77
BN49 StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £14.97
Length: 1m
