Connect USB Micro-B devices to your USB-C host, using this durable 1-meter cable. Need to connect a USB Micro-B device to a USB-C device? This 1m USB-C to Micro-B cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
With a bandwidth of 10 Gbps, this USB 3.1 Gen 2 cable lets you connect your USB 3.1 Micro-B devices such as hard drive enclosures and docks to your laptop, at speeds like never before. Now, you can spend less time transferring and backing up your data and more time focusing on your projects and presentations. USB 3.1 is twice the speed of USB 3.0 and 20x faster than USB 2.0.
You'll also be able to connect older USB 3.0 peripheral devices to newer computers with data transfer speeds of up to 5 Gbps.
Connect your Micro USB 3.0 phone or tablet to your USB 3.1 laptop or desktop computer for syncing and charging. The cable can provide up to 3A for powering your devices, where supported.
Reliable performance
Featuring USB 3.1 technology, this cable ensures rapid data transfer rates of up to 10 Gbps, facilitating efficient sync and charging between compatible devices. -
Versatile compatibility
Equipped with a male 24 pin USB-C connector and a male 10 pin Micro-USB Type-B connector, this cable accommodates a wide variety of devices. -
Robust construction
The double shielded design minimizes interference, while the nickel-plated connectors contribute to a durable and reliable connection that withstands daily use.
- StarTech.com USB C to Micro USB Cable - 3 ft / 1m - USB 3.1 - 10Gbps - Micro USB Cord - USB Type C to Micro USB Cable (USB31CUB1M) - USB-C cable - 24 pin USB-C to Micro-USB Type B - 1 m
- USB-C cable
- Technology
- Double shielded
- Length
- 1 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 10 pin Micro-USB Type B - male
- USB 3.1
- Black
- 2-year warranty
- Designed For
- P/N: HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, PEXUSB311AC2, PEXUSB311AC3, PEXUSB312A1C1H, PEXUSB312A2C2V, PEXUSB312C2, PEXUSB312C3, PEXUSB312EIC, PEXUSB321C, S251BPU31C3, S251BU31315, S251BU31REM, SM21BMU31C3, SM22BU31C3R, SMS2BU31C3R
- USB-C cable
- Technology
- Double shielded
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- USB 3.1, RoHS, USB-IF
- 2-year warranty
- Designed For
StarTech.com 1m USB 2.0 C to Micro-USB Cable | In Stock | £7.73 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £9.01 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £7.59 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £11.56 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £13.21 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £10.31 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £9.97 |
StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £9.01 |
StarTech.com USB 3.0 USB-C to USB-A Adapter | In Stock | £8.24 |
StarTech.com USB-C to Micro-USB Adapter M/F | In Stock | £4.62 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.87 |
StarTech.com 0.5m USB 3.1 C - Micro B Cable | In Stock | £9.59 |
StarTech.com 1m 3ft USB 3.1 C to B Cable | In Stock | £17.57 |
