StarTech.com 1m USB A to C Cable - USB 2.0
Quicklinx: CY2RWS00 Mfr#: USB2AC1MR
Length: 1m
11 In Stock
£10.06 ex VAT
£12.07 inc VAT
Connect your USB Type-C devices to your computer, with the cable out of the way. This right-angle USB to USB-C cable is great for charging your mobile devices in a car, or for accessing your phone or tablet while it's connected to a wall charger or laptop.
The cable features a right-angled USB Type-C connector that lets you connect to ports that are difficult to reach, which is perfect for charging your car-mounted mobile devices. You can position the cable to the left or right of your mobile device, in either portrait or landscape mode. Even while you're charging your mobile device, you can use it to text, work or game, without the cable getting in the way.
The angled connector also prevents the cable from bending awkwardly or from straining too much to make a connection. It offers a more natural fit at the connection point, preventing unnecessary stress and damage to the cable and device port.
Replace the USB to USB-C cable that came with your mobile device, or keep one as a spare while traveling so that your mobile devices will be ready to use while you're on the road.
  • Connect with ease
  • Charge and sync your USB mobile devices
    Replace the USB to USB-C cable that came with your mobile device or keep one as a spare while traveling so that your mobile devices will be ready to use while you're on the road.
StarTech.com USB to USB C Cable - 1m / 3 ft - Right Angle USB Cable - USB A to USB C Cable - USB 2.0 Cable - USB Type C Cable (USB2AC1MR) - USB cable - USB to 24 pin USB-C - 1 m
USB cable
Sync and charge
Length
1 m
Connector
4 pin USB Type A - male - straight
Connector (Second End)
24 pin USB-C - male - right-angled
USB / USB 2.0
USB cable
Jacket Material
PVC
American Wire Gauge (AWG)
24/30
Plated Connector
Nickel
Sync and charge
Length
1 m
50 g
Connector
USB / USB 2.0, RoHS, WEEE
CY2R StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £9.09
CY2R StarTech.com 0.5m USB 2.0 C to A Cable M/M In Stock £8.26
CY2R StarTech.com 1m USB A to C Cable - USB 2.0 In Stock £10.06
CY2R StarTech.com 1m Right Angle USB C Cable In Stock £11.21
Length: 1m
