Connect your USB Type-C mobile device to a USB-A host, using a standard Micro-USB Cable. This USB-C to Micro-USB adapter lets you charge and sync USB Type-C mobile devices, such as the Nokia N1 tablet and Nexus 6P and 5X phones, using a Micro-USB cable.
Simply insert the adapter's USB-C connector into your mobile device. Then, plug your Micro-USB cable into the adapter's Micro-USB port and connect the cable to the USB-A port on your computer or USB-A wall charger.
The compact adapter is portable enough for carrying as a tablet or laptop accessory and it reduces the number of cables that you need to carry around with you in order to charge all of your mobile devices.
- StarTech.com USB C to USB Micro B - USB Type C to USB M / F - USB 2.0 - USB C Connector - USB-C to USB Micro B Adapter (USB2CUBADP) - USB-C adapter - 24 pin USB-C to Micro-USB Type B
- USB-C adapter
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 5 pin Micro-USB Type B - female
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C adapter
- Plated Connector
- Nickel
- Black
- 5.1 g
- Connector
- USB / USB 2.0, RoHS
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £10.84 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £10.98 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £11.16 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £14.29 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £9.37 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £17.06 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.44 |
