StarTech.com 10m USB 2.0 Active Extension Cable - M/F
Quicklinx: 97F5WS00 Mfr#: USB2AAEXT10M
Length: 10m
14 In Stock
£53.10 ex VAT
£63.72 inc VAT
Extend the distance between a computer and a USB 2.0 device by 10 meters. The USB2AAEXT10M 10m Active USB 2.0 Extension Cable offers one USB-A male connector and one USB-A female connector, and provides an active extension of USB 2.0 devices of up to 10-meters (30-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations, the active USB 2.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables.
Up to 4 of these cables can be daisy-chained together, allowing for a total USB extension of up to 40-meters. If necessary, the USB device can be powered from a wall outlet using the Universal AC power adapter (provided with the cable).
The USB2AAEXT10M repeater cable supports the full USB 2.0 bandwidth of 480 Mbps.
  • Reliable connectivity
    The cable utilizes active technology to regenerate signals, allowing for consistent data transfer over longer distances without degradation.
  • Versatile compatibility
    With USB Type-A connectors on both ends, this extension cable is suitable for a wide range of devices including printers and external storage.
  • High-quality construction
    Constructed with shielded materials and nickel-plated connectors, this cable ensures a reliable and stable connection compared to standard cables.
  • Standards compliance
    The cable meets USB 2.0 standards and is compliant with FCC and RoHS regulations, ensuring safety and reliability in use.
StarTech.com 10m USB 2.0 Active Extension Cable M/F - 10 meter USB 2.0 Repeater / Extender Cable USB A (M) to USB A (F) 10 m Black - 3 ft (USB2AAEXT10M) - USB extension cable - USB to USB - 10 m
USB extension cable
Shielded
Active cable (signal regeneration)
Length
10 m
Connector
4 pin USB Type A - female
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
P/N: LTUB1MBK, SVA5H2NEUA, UUSBOTG
USB extension cable
Shielded
Plated Connector
Nickel
Length
10 m
Connector
USB / USB 2.0, FCC, RoHS
97F5 StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £5.00
97F5 StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.06
97F5 StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.19
97F5 StarTech.com 20m USB 2.0 Active Extension Cable - M/F In Stock £76.40
97F5 StarTech.com 15m USB 2.0 Active Extension Cable - M/F In Stock £61.53
97F5 StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £14.23
97F5 StarTech.com 10m USB 2.0 Active Extension Cable - M/F In Stock £53.10
97F5 StarTech.com 25m USB 2.0 Active Extension Cable - M/F In Stock £95.30
97F5 StarTech.com 5m USB 2.0 Active Extension Cable - M/F In Stock £37.96
Length: 10m
