Extend the distance between a computer and a USB 2.0 device by 15 meters. The USB2AAEXT15M 15m Active USB 2.0 Extension Cable, offers one USB ''A'' male connector and one USB ''A'' female connector, and provides an active extension of USB 2.0 devices of up to 15-meters (49.2-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations, the active USB 2.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables.
Up to 4 of these cables can be daisy-chained together, allowing for a total USB extension of up to 60-meters. If necessary, the USB device can be powered from a wall outlet using the Universal AC power adapter (provided with the cable).
The USB2AAEXT15M repeater cable supports the full USB 2.0 bandwidth of 480 Mbps.
Dependable connection
This USB extension cable features an active design that regenerates signals, allowing for consistent data transmission over longer distances without signal loss. -
Extended reach
With a length of 15 m, this cable supports greater flexibility in device placement, helping to connect devices that are further apart. -
Interference reduction
The shielded technology used in this cable aids in reducing electromagnetic interference, ensuring clear and precise communication between connected devices. -
Durable connectors
Nickel-plated connectors enhance the cable's robustness, providing resistance to corrosion and ensuring a long-lasting connection. -
Wide compatibility
Designed to comply with USB 2.0 standards, this extension cable works seamlessly with a variety of devices, making it a versatile choice for different setups.
- StarTech.com 15m USB 2.0 Active Extension Cable - M/F - 15 meter USB 2.0 Repeater Cable Cord - USB A Male to USB A Female - 15 m, Black (USB2AAEXT15M) - USB extension cable - USB to USB - 15 m
- Technology
- Shielded
- Active cable (signal regeneration)
- Length
- 15 m
- Connector
- 4 pin USB Type A - female
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- 2-year warranty
- Designed For
- P/N: SVA5H2NEUA, UUSBOTG
- Technology
- Shielded
- Plated Connector
- Nickel
- Length
- 15 m
- Black
- Connector
- USB / USB 2.0, FCC, RoHS
- 2-year warranty
- Designed For
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £5.00 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.06 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.19 |
StarTech.com 20m USB 2.0 Active Extension Cable - M/F | In Stock | £79.94 |
StarTech.com 15m USB 2.0 Active Extension Cable - M/F | In Stock | £61.53 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £16.70 |
StarTech.com 10m USB 2.0 Active Extension Cable - M/F | In Stock | £53.10 |
StarTech.com 25m USB 2.0 Active Extension Cable - M/F | In Stock | £95.30 |
StarTech.com 5m USB 2.0 Active Extension Cable - M/F | In Stock | £37.96 |
