StarTech.com USB Extender Hub, 24m, USB 2.0
Quicklinx: HDFXWS00 Mfr#: U02442-USB-EXTENDER
Type: USB Extender
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
Form Factor: External
Hurry, only 3 left in stock!
£148.64 ex VAT
£178.36 inc VAT
The 4-Port USB 2.0 Extension Cable (78.7ft/24m) enables multiport connectivity at distances that exceed standard USB 2.0 distance and power source limitations. Daisy chain two USB active extension cables for a maximum range of 157.4ft (48m).
  • Power Options
    Active electronics allow the USB-A Hub to work without external power, multiplying the installation possibilities and accelerating any deployment. In addition, the 5V2A DC power adapter supports USB peripherals requiring additional power. Control multiple USB peripherals in remote locations (e.g., webcams, CCTV remote monitoring, remote printers, SSDs, HDDs, scales, mice, keyboards, and other devices), using this 4-port 78.7ft (24m) USB extension cable.
  • Host and Device Compatibility
    The backward compatibility with USB 1.1 and 1.0 ensures functionality with legacy equipment. The hub/cable features plug and play (PnP) setup on any operating system, enabling rapid deployment. The level 4 ESD protection (15kV air and 8kV contact) and the cable shielding enhance USB device safety and minimize EMI. The USB extender hub is backed for two years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com USB Extender Hub, 24m USB 2.0 Extension Cable with 4-Port USB Hub, Active/Bus Powered USB Repeater Cable, Optional 10W Power Supply Included - USB-A Hub w/ ESD Protection (U02442-USB-EXTENDER) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
Performance
Maximum data rate: 480 Mpps
8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge)
USB 1.1, USB 2.0
4.2 cm x 24.1 cm x 1.7 cm
Black, silver
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
Performance
USB 1.1, USB 2.0
X Terminus Tech FE1.1
Status Indicators
1 x USB 2.0 Type A , 4 x USB 2.0 Type A , 1 x terminal block
Black, silver
1 x USB active cable - 24 m
FCC, WEEE
4.2 cm
24.1 cm
1.7 cm
Shipping Width
18 cm
Shipping Depth
22 cm
Shipping Height
5.5 cm
Shipping Weight
1 kg
Limited warranty - 2 years , Technical support - assistance - lifetime
50 °C
30 - 70%
Min Storage Temperature
-20 °C
Max Storage Temperature
75 °C
Type: USB Extender
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
