The USB2AAEXT5M 5m Active USB 2.0 Extension Cable offers one USB-A male connector and one USB-A female connector, and provides an active extension of USB 2.0 devices of up to 5-meters (15-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations, the active USB 2.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables. Plus you can daisy chain 4 cables for a total USB extension of up to 20-meters.
If necessary, the cable can be powered from a wall outlet using the Universal AC power adapter that was provided with the cable - this will allow you to use USB bus-powered devices that may require extra power.
The USB2AAEXT5M repeater cable supports the full USB 2.0 bandwidth of 480 Mbps.
Reliable Connectivity
This USB extension cable ensures reliable data transfer over longer distances thanks to its active cable design that regenerates signals. -
User-Friendly Operation
The Plug-and-Play compatibility allows for effortless connection without the need for additional drivers or software installations. -
Durable Design
Constructed with nickel-plated connectors, this cable offers enhanced resistance to wear and corrosion, ensuring longevity. -
Improved Compatibility
Engineered to work seamlessly with different USB devices, this extension cable provides flexibility in various settings.
- StarTech.com 5m USB 2.0 Active Extension Cable M/F - 5 meter USB A Male to USB A Female USB 2.0 Repeater / Extender Cable - Black - 15ft (USB2AAEXT5M) - USB extension cable - USB to USB - 5 m
- Technology
- Shielded
- Active cable (signal regeneration), LED power indicator
- Length
- 5 m
- Connector
- 4 pin USB Type A - female
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- 2-year warranty
- Designed For
- P/N: LTUB1MBK, SVA5H2NEUA, UUSBOTG
- Technology
- Shielded
- Plated Connector
- Nickel
- Length
- 5 m
- Black
- Connector
- USB / USB 2.0, Plug and Play, FCC, RoHS
- 2-year warranty
- Designed For
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £5.00 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.06 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.19 |
StarTech.com 20m USB 2.0 Active Extension Cable - M/F | In Stock | £79.94 |
StarTech.com 15m USB 2.0 Active Extension Cable - M/F | In Stock | £61.53 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £16.70 |
StarTech.com 10m USB 2.0 Active Extension Cable - M/F | In Stock | £53.10 |
