StarTech.com 5m USB 2.0 Active Extension Cable - M/F
Quicklinx: 9J4BWS00 Mfr#: USB2AAEXT5M
Length: 5m
25 In Stock
£37.03 ex VAT
£44.43 inc VAT
The USB2AAEXT5M 5m Active USB 2.0 Extension Cable offers one USB-A male connector and one USB-A female connector, and provides an active extension of USB 2.0 devices of up to 5-meters (15-feet).
An all-in-one cable for overcoming distance restrictions as well as power source limitations, the active USB 2.0 extension cable incorporates bus-powered active circuitry to ensure performance beyond the length limits of standard USB cables. Plus you can daisy chain 4 cables for a total USB extension of up to 20-meters.
If necessary, the cable can be powered from a wall outlet using the Universal AC power adapter that was provided with the cable - this will allow you to use USB bus-powered devices that may require extra power.
The USB2AAEXT5M repeater cable supports the full USB 2.0 bandwidth of 480 Mbps.
  • Reliable Connectivity
    This USB extension cable ensures reliable data transfer over longer distances thanks to its active cable design that regenerates signals.
  • User-Friendly Operation
    The Plug-and-Play compatibility allows for effortless connection without the need for additional drivers or software installations.
  • Durable Design
    Constructed with nickel-plated connectors, this cable offers enhanced resistance to wear and corrosion, ensuring longevity.
  • Improved Compatibility
    Engineered to work seamlessly with different USB devices, this extension cable provides flexibility in various settings.
StarTech.com 5m USB 2.0 Active Extension Cable M/F - 5 meter USB A Male to USB A Female USB 2.0 Repeater / Extender Cable - Black - 15ft (USB2AAEXT5M) - USB extension cable - USB to USB - 5 m
USB extension cable
Shielded
Active cable (signal regeneration), LED power indicator
Length
5 m
Connector
4 pin USB Type A - female
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
P/N: LTUB1MBK, SVA5H2NEUA, UUSBOTG
USB extension cable
Shielded
Plated Connector
Nickel
Length
5 m
Connector
USB / USB 2.0, Plug and Play, FCC, RoHS
9J4B StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £5.02
9J4B StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.04
9J4B StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.29
9J4B StarTech.com 20m USB 2.0 Active Extension Cable - M/F In Stock £74.54
9J4B StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £14.49
9J4B StarTech.com 10m USB 2.0 Active Extension Cable - M/F In Stock £51.00
9J4B StarTech.com DC Power Adapter - 5V, 2A In Stock £9.67
Length: 5m
