The connected thermostat that personalizes your comfort according to your house and your habits.
Enjoy comfort with ease
Because not everyone has the same concept of comfort, Somfy has developed the Connected Thermostat which personalises your comfort according to your house and your habits. And all that whilst helping you to reduce your energy bill. Adjust the temperature on the thermostat or using the iOS or Android smartphone app.
- Humidity sensor
- Geolocation function
- Self-learning based on your home environment
- Open window detection
- Access management: child / adult account
MORE COMFORT WITH MORE SENSORS The connected thermostat takes into account both the temperature and humidity levels in your home, to be closer to the temperature you actually feel and offers you maximum comfort.
KEEP AN EYE ON YOUR ENERGY CONSUMPTION AND RECEIVE PERSONALIZED ENERGY COACHING. The Somfy connected thermostat analyses the energy performance of your home, the weather conditions and your usage habits. You can view in real time, on the smartphone application, the estimated amount of your energy bill. Personalized advice will be offered to improve your consumption and reduce its impact on your bill.
ENJOY MORE FREEDOM THANKS TO GEOLOCATION AND REMOTE CONTROL. The Somfy connected thermostat automatically adapts to you schedule. By activating the geolocation function, when you move away from home, the temperature decreases, and as you get closer, it increases.
ENJOY THE SOMFY ECOSYSTEM With TaHoma, combine your thermostat with your Somfy blinds for even greater efficiency. You can create a "smart" programming combining thermostat, sun sensor and blinds to save even more energy.
Contents - 1x thermostat - 1x internet gateway - 2x AA batteries - 2x 1m cable - 1x manual - 1x quickstart guide
More comfort with more sensors
The connected thermostat takes into account both the temperature and humidity levels in your home, to be closer to the temperature you actually feel and offers you maximum comfort. -
Keep an eye on your energy consumption and receive personalized energy coaching
The Somfy connected thermostat analyses the energy performance of your home, the weather conditions and your usage habits. You can view in real time, on the smartphone application, the estimated amount of your energy bill. Personalized advice will be offered to improve your consumption and reduce its impact on your bill. -
Enjoy more freedom thanks to geolocation and remote control
The Somfy connected thermostat automatically adapts to you schedule. By activating the geolocation function, when you move away from home, the temperature decreases, and as you get closer, it increases. -
Enjoy the Somfy ecosystem
- Somfy Connected Smart Thermostat - Wired - thermostat - Wi-Fi - grey, white
- Product Type
- Thermostat
- Functions
- Temperature measuring, humidity measurement
- Power Source
- Battery
- Internet of Things (IoT) Platform
- Google Home, Somfy TaHoma
- Intelligent Assistant
- Alexa
- Connectivity
- Wireless - Wi-Fi
- Grey, white
- 5-year warranty
- 10.2 cm x 3.5 cm x 9 cm
- Product Type
- Thermostat
- Functions
- Power Source
- Battery
- Connectivity Technology
- Wireless - Wi-Fi
- OS Required
- Android, Apple iOS
- Temperature Range
- 5 - 26 °C
- Platform
- Compatible Services
- IFTTT
- Alexa
- Form Factor
- AA type
- Battery Included
- Required Qty
- 2
- Included Accessories
- Gateway
- Grey, white
- Warranty
- 5-year warranty
- ISO 140001, OHSAS 18001, EN 62479:2010, ISO 90001
- 10.2 cm
- 3.5 cm
- 9 cm
- 116 g
- Dimensions & Weight Details
- Gateway: 6 cm x 6.2 cm x 7.15 cm x 75 g , Thermostat: 10.2 cm x 3.5 cm x 9 cm x 108 g
