Netatmo Smart Thermostat
Quicklinx: D3WPWS00 Mfr#: NTH01-EN-EU
Type: Thermostat
Compatible With: Alexa, Siri, Google Assistant
£133.33 ex VAT
£159.99 inc VAT
Netatmo smart thermostat
37% less energy on average to heat your home
Control your heating remotely
Use your Netatmo Thermostat to change your home's temperature, from your bed or from the other side of the world.
Schedule your heating for your return from a holiday.
Right temperature at the right time
The Thermostat uses your answers to 5 questions to create a schedule that’s based on your habits and lifestyle, so you only use the heating when you need it.
Smart heating in your home
Auto-Adapt function
The Netatmo Thermostat’s Auto-Adapt function uses your home’s insulation and the outdoor temperature to programme when your heat should switch on. So you can have the temperature you want at just the right time.
Auto-Care function
Thanks to its Auto-Care function, the Netatmo Thermostat can tell you when its batteries are low, or notify you of a problem with your heating system’s operation.
Control your heating using just your voice
Apple Homekit: "Siri, set my thermostat to 20°C"
Amazon Alexa: "Alexa, decrease my thermostat temperature by 3°C"
Google Assistant: "Ok Google, set the thermostat to 21 degrees'"
Receive our money-saving tips
Every month, you receive your customised Energy Savings Report. The report will help you track your consumption and adjust your heating schedule for optimal savings.
Track your consumption
Display your past energy consumption.
Your indoor temperature and boiler activity are recorded continuously in the App.
  • Energy savings
    Save on your energy consumption and reduce your carbon footprint with the Netatmo Thermostat.
  • Control your heating remotely
    Use your Netatmo Thermostat to change your home's temperature, from your bed or from the other side of the world. Schedule your heating for your return from a holiday.
  • Right temperature at the right time
    The Thermostat uses your answers to 5 questions to create a schedule that's based on your habits and lifestyle, so you only use the heating when you need it.
  • Auto-adapt function
    The Netatmo Thermostat's Auto-adapt function uses your home's insulation and the outdoor temperature to program when your heat should switch on. So you can have the temperature you want at just the right time.
  • Auto-care function
    Thanks to its Auto-care function, the Netatmo Thermostat can tell you when its batteries are low, or notify you of a problem with your heating system's operation.
Netatmo smart thermostat - by Stark - thermostat - 802.11b/g/n
Thermostat
Environment
Indoor
Functions
Temperature measuring, control heating systems
Power Source
Intelligent Assistant
Siri, Google Assistant, Alexa - indirect
Wireless - 802.11b/g/n
Frequency Band
2.4 Ghz
Supported Host Device OS
iOS, Android, Windows Phone
Display
E Ink
8.3 cm x 2.2 cm x 8.3 cm
Thermostat
Environment
Indoor
Functions
Power Source
Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Max Range Open Space
100 m
Frequency Band
2.4 Ghz
Android 4.2 (Jelly Bean) or later, iOS 9 or later
Display
E Ink
Auto-Adapt function, Auto-Care function, switching current up to 4 A, switching voltage up to 250 VAC
Temperature Range
5 - 30 °C
Measurement Accuracy
±0.5 °C
Internet of Things (IoT)
Hub
Included
Hub Compatibility
Netatmo Relay
Voice Controlled
Indirect
Thermostat
Modes
Auto, programme
Multi-zone
AAA type
Required Qty
3
Battery Lifetime
2 years
Power adapter, wall mount, stand, USB cable, 3 AAA batteries, boiler adapter, screws, mounting plate, 4 colour adhesives, relay
Product Material
Plexiglas
Encryption Algorithm
AES, TKIP, WPA, WPA2, WEP
Warranty
8.3 cm
2.2 cm
8.3 cm
50 °C
Type: Thermostat
Compatible With: Siri
Brand: Netatmo
