Netatmo Smart Heating Bundle with Professional Installation
Quicklinx: FFMBWS00 Mfr#: NBU-NTH-NAV-EU
Type: Thermostat kit
Compatible With: Alexa, Google Assistant, Siri
Stock Status: In Stock, Used Stock
28 in stock
£224.99 ex VAT
£269.98 inc VAT
Express delivery Order within the next 22 hours for delivery on Friday
Bundle includes:
Netatmo Smart Thermostat
3 x Smart Radiator Valves
FREE Professional Installation
Upgrade to smart heating
Discover Netatmo smart heating solutions, and save energy to heat your home without giving up on comfort, whatever heating system you have
Control your heating remotely
Use our Energy app or Legrand's Home + Control App to control your heating from your smartphone and change the temperature at home from your bed or from the other side of the world. Schedule your heating for your return from a holiday.
Right temperature at the right time
The Thermostat uses your answers to 5 questions to create a schedule that’s based on your habits and lifestyle, so you only use the heating when you need it.
Auto-Adapt function
The Netatmo Thermostat’s Auto-Adapt function uses your home’s insulation and the outdoor temperature to programme when your heat should switch on. So you can have the temperature you want at just the right time.
Auto-Care function
Thanks to its Auto-Care function, the Netatmo Thermostat can tell you when its batteries are low, or notify you of a problem with your heating system’s operation.
Works with
Works with Apple HomeKit, Alexa and Google Assistant, so you can control your heating with your voice.
Netatmo Smart Radiator Valves
Save even more energy
Complete your Smart Thermostat or your Starter Pack for district heating with Additional Smart Radiator Valves and take control of all your individual radiators.
Thanks to the room-by-room schedule based on your daily routine, heat according to individual room use and save even more energy.
Open Window Detection
When the Smart Radiator Valve detects a window is open, it switches off the heating in the room to prevent energy waste.
Smart Regulation
The Smart Radiator Valve analyzes the room environment in real time and adjusts heating according to sunshine level and room use.
Manual Boost
When needed, the temperature can be temporarily raised in a specific room for 3 hours.
4 interchangeable colours
Customise your Valve with one of the four colour adhesive strips provided.
Manual temperature adjustment
Turn up the Valve to manually change the temperature setpoint.
Real-time temperature
Display the real time temperature in the room.
Mechanics and design
Optimized for energy savings, 2-year battery life.
This product comes with free installation. You will receive a unique code on your packaging. Follow the instructions and use your code to redeem the installation online.
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: FFMB 041553
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £183.03
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Compatible With: Siri
Brand: Netatmo
Stock Status: Used Stock
Price Range Ex VAT: 150 - 300
