tado Wireless Smart Thermostat v3+ Kit & 4xSRT Bundle
Quicklinx: GQV8WS00 Mfr#: THERMOV3-TRVX4-KTS
Type: Thermostat
Compatible With: Alexa, Google Assistant
£357.50 ex VAT
£429.00 inc VAT
The tado bundle for total control of your heating across the most important rooms in your house!
1 x tado Wireless Smart Thermostat v3+ Starter Kit
4 x Smart Radiator Thermostats
Worried about the energy price rise?
  • Control each room’s temperature independently
  • Save up to 31% of energy and maximise comfort
  • Control your heating and hot water to suit your routine
  • Get notified to turn off your heating when a window is open or nobody is home
  • Install easily and wirelessly and control with your voice
Product Details:
Starter Kit - Wireless Smart Thermostat v3+:
The smart way to control your heating and hot water
Replace your old thermostat with the tado° Smart Thermostat with Hot Water Control and experience a new level of comfort and control, whilst saving energy and reducing your heating bills.
Easy to install
This Starter Kit can be self-installed and tado° provides easy to follow instructions based on your current heating set-up.
The tado° Smart Thermostat with Hot Water Control works with combi-boilers and those with a hot water tank. It includes the tado° Extension Kit, which allows the Smart Thermostat to operate wirelessly, meaning you can position it wherever you desire.
Easy to use
The highly rated tado° app enables you to schedule and control your heating and hot water from anywhere, as well as providing insights and reports about your home climate and showing you the energy savings made by tado°.
tado° is also compatible with Amazon Alexa, Apple HomeKit and Google Assistant, meaning you can control your heating and hot water with your voice, as well as integrating it into routines with your other smart home devices.
Smart Radiator Thermostat Add-on (4 included):
Want to control your temperature even more conveniently and precisely? Add additional Smart Radiator Thermostats to your Starter Kit.
You want to control your rooms individually in just one app?
Simply replace your conventional radiator thermostats with tado°. For example, you can create and manage intelligent schedules for each room.
Install it yourself
To connect your additional Smart Radiator Thermostat, simply follow the instructions in your tado° app. You’ll need no expert knowledge to accomplish the installation in just a few minutes. There is no risk of water leakage during the installation.
Save up to 31% on your heating bills!
tado° comes with an Energy Savings Guarantee - if you are not satisfied that tado° has saved you energy in the first 12 months, simply return the product to tado° and get your money back, no questions asked!
tado° Wireless Smart Thermostat - v3+ - Starter Kit - thermostat - matt white
Thermostat
Functions
Control heating systems
Integrated Sensors
Humidity, temperature
Power Source
Battery, power adapter
Internet of Things (IoT) Platform
Apple HomeKit
Intelligent Assistant
Google Assistant, Alexa
Package Content
Temperature sensor, wireless receiver, bridge
Wireless
Frequency Band
868 MHz
Display
LED
Matt white
United Kingdom
Thermostat
Functions
Integrated Sensors
Power Source
Package Content
Wireless
Frequency Band
868 MHz
Display
LED
Light sensor, touch control 6LoWPAN
Measurement Accuracy
±0.01 °C
Platform
Apple HomeKit
Compatible Services
IFTTT
Thermostat
Modes
Manual, programme
Aerial
Internal
AAA type
Battery Included
Required Qty
3
Network cable, USB cable, screws, screwdriver, 2 adhesive pads, 3 terminal connectors
Product Material
Polycarbonate, ABS plastic
Matt white
United Kingdom
Warranty
Dimensions & Weight Details
Temperature sensor: 10.4 cm x 1.9 cm x 10.4 cm x 137 g , Bridge: 2.7 cm x 2.2 cm x 8.1 cm x 30 g , Wireless receiver: 14 cm x 1.8 cm x 8 cm x 146 g
Type: Thermostat
Brand: tado
