This is a very flexible solution mounted on wheels that allows the screen to be rotated from a vertical to a horizontal position after mounting. The bracket is easy to add shelves and cabinets for DVDs and other peripherals.
- SMS Flatscreen X FH M1455 stand - for flat panel - white, aluminium
- Product Type
- Stand - floor-standing
- 88.3 cm x 69.1 cm x 162 cm
- Adjustments
- Tilt
- Recommended Use
- Flat panel
- Recommended Display Size
- 40"-60"
- VESA Mounting Interface
- 200 x 200 mm, 800 x 400 mm
- Max Load Weight
- 50 kg
- White, aluminium
- 5-year warranty
- 88.3 cm
- 69.1 cm
- 162 cm
- White, aluminium
AV Furniture
- Stand
- Recommended Use
- Flat panel
- Placing / Mounting
- Floor-standing
- 40"-60"
- Adjustments
- Tilt
- Max Load Weight
- 50 kg
- Wheels
- Limited warranty - 5 years
