Proper Swing Arm Tilting TV Wall Bracket 40"-63"
Quicklinx: 8PMHWS00 Mfr#: LPA29-482
Type: Wall mount
More than 50 in stock
£24.99 ex VAT
£29.98 inc VAT
This premium swing arm wall mount provides the perfect solution for all large LED, LCD and Plasma television screens. With the combination of both the cantilever and tilting functions it enables you to adjust the position of the television to fit all purposes. The bracket includes an integrated spirit level helping accurate alignment installation, and an easy grip dial to enable tool-less bracket tilting.
  • Distinctive chic design
  • -10° to +15° up and down tilt
  • Built-in screen level adjustment -4° to +4°
  • Universal hole patterns up to 600 x 400mm
  • VESA compliant: 100x100, 200x100, 200x200, 400x200, 400x400, 600x400
  • Integrated bubble level assures easy installation alignment
  • Locking hole design for anti-theft (requires a padlock)
  • Mounting profile: 77-548mm
  • Supports flat panel tv up to 40kgs
Proper premium Universal Tilting TV Bracket - wall mount
Wall mount
Adjustable Depth
7.7-54.8 cm
Adjustments
Levelling, tilt
Recommended Use
LCD / plasma panel
Recommended Display Size
40"-63"
Flat Panel Mount Interface
100 x 100 mm, 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 800 x 400 mm, 600 x 400 mm, 200 x 100 mm
Max Mounting Pattern Size
810 x 404 mm
Max Load Weight
40 kg
Adjustable Depth
7.7-54.8 cm
AV Furniture
Wall mount
Mounting Components
Wall mount, swing arm
Recommended Use
LCD / plasma panel
810 x 404 mm
40"-63"
Adjustments
Levelling, tilt
Max Load Weight
40 kg
Swivel adjustment, anti-theft, integrated spirit level
Type: Wall mount
Brand: Proper
Price Range Ex VAT: 0 - 50
