Peerless-AV SmartMount Articulating Wall Mount for 50"-80" Displays
Quicklinx: 7MVNWS00 Mfr#: SA771PU
Type: Mounting kit
10 In Stock
£431.54 ex VAT
£517.84 inc VAT
From any angle, this wall mount reflects remarkable form and function. Extending the flat panel display up to 27.55" (700mm) from the wall and allowing for viewing in any part of the room. Fine-tuning of the installation is simple with its side-to-side display leveling and 1" (25mm) of vertical adjustment features that help achieve installation perfection. This Full-Motion Plus Wall Mount also provides display centering on the wall plate and integrates a desirable cable management system, centering the TV on the wall when retracted and organizing and protecting the cables at all times. Designed and built in the USA, this mount maintains the same brilliant look as the entire SmartMount 700 Series line of Full-Motion Plus Wall Mount and Pivot Wall Mounts.
  • Versatile viewing
    With adjustments for tilt and a full-motion plus wall mount, this mounting kit offers optimal viewing angles for any setup, ensuring a comfortable and customizable viewing experience.
  • Robust support
    Designed to hold large LCD displays ranging from 46"-90" or 116.8-228.6 cm and capable of supporting up to 68.04 kg, this mount provides a secure and stable platform for your premium display units.
  • Seamless integration
    The articulating arm and wall plate components ensure a smooth installation process, fitting flat panel mount interfaces up to 800 x 400 mm, making it a versatile choice for a wide range of LCD displays.
Peerless Universal Full-Motion Plus Wall Mount SA771PU mounting kit - for LCD display
Mounting kit
Mounting Components
Wall plate, articulating arm
112.9 cm 66.1 cm
Adjustments
Tilt
Recommended Use
LCD display
Recommended Display Size
46"-90"
VESA Mounting Interface
Up to 800 x 400 mm
Max Load Weight
68.04 kg
112.9 cm
66.1 cm
AV Furniture
Mounting kit
Mounting Components
Recommended Use
LCD display
Up to 800 x 400 mm
46"-90"
Adjustments
Tilt
Max Load Weight
68.04 kg
Type: Mounting kit
Brand: Peerless-AV
