Samsung 9100 PRO, PCIe 5.0, NVMe M.2 SSD, 2TB
Quicklinx: J3T6WS00 Mfr#: MZ-VAP2T0BW
The Samsung 9100 PRO MZ-VAP2T0 delivers performance with a storage capacity of 2 TB. Utilizing Samsung V-NAND TLC Technology and Intelligent TurboWrite 2.0 Technology, this internal solid-state drive ensures high-speed data transfers with internal data rates of up to 14,700 MBps for read and 13,400 MBps for write operations. The M.2 2280 form factor makes it a compact choice for various devices, enhancing overall system responsiveness. Designed for reliability, the drive features a robust integrated heatsink and supports TRIM along with Auto Garbage Collection Algorithms, which help maintain optimal performance over time. With compliance to NVMe 2.0 and a PCI Express 5.0 x4 interface, this SSD is suitable for heavy-duty tasks. The device tolerance against shock and vibration ensures durability, while the hardware encryption offers data security for sensitive information.
  • High storage capacity
    With 2 TB of storage, this SSD accommodates large files and applications, making it ideal for gamers, content creators, and professionals who require ample space.
  • Fast data transfer rates
    Achieving internal data rates of 14,700 MBps for read operations and 13,400 MBps for write operations, this SSD accelerates file transfer and loading times.
  • Advanced thermal management
    The integrated heatsink effectively dissipates heat, ensuring stable performance during intensive tasks and extending the lifetime of the drive.
  • Enhanced data security
    This SSD is equipped with 256-bit AES hardware encryption, providing security for sensitive files and complying with TCG Opal Encryption 2.0.
  • Durable design
    Built to withstand shocks of up to 1500 g, this SSD features a reliability rating of 1.5 million hours MTBF, ensuring longevity and dependability in various environments.
Samsung 9100 PRO MZ-VAP2T0 - SSD - 2 TB - PCI Express 5.0 x4 (NVMe)
Solid state drive - internal
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
TRIM support, Auto Garbage Collection Algorithm, Device Sleep support, Samsung V-NAND TLC Technology, integrated heatsink, Intelligent TurboWrite 2.0 Technology, PlayStation compatible, NVMe 2.0, S.M.A.R.T.
Enclosure Colour
22.15 mm x 80.15 mm x 2.38 mm
9 g
5-year warranty
2 TB
Hardware Encryption
256-bit AES
M.2 2280
22.15 mm
80.15 mm
2.38 mm
9 g
Performance
SSD Endurance
1200 TB
Internal Data Rate
14700 MBps (read) / 13400 MBps (write)
Maximum 4KB Random Write
2600000 IOPS
Maximum 4KB Random Read
1850000 IOPS
Reliability
MTBF
1.500.000 hours
Expansion & Connectivity
Compatible Bay
M.2 2280
Power Consumption
8.1 watt (read) , 7.9 watt (write) , 4.8 watt (idle) , 4 mW (sleep)
Software Included
Samsung Magician Software
IEEE 1667
Enclosure Colour
Package Details
Box
Limited warranty - 5 years / 1200 TBW
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine
Vibration Tolerance (non-operating)
20 g @ 20-2000 Hz
