Samsung SSD INT 990 EVO PLUS 4TB PICE M.2
Quicklinx: HXZ6WS00 Mfr#: MZ-V9S4T0BW
Form Factor: M.2 2280
Type: Solid state drive
Capacity: 4TB
More than 50 In Stock
£736.72 ex VAT
£884.06 inc VAT
The Samsung 990 EVO Plus is a powerful internal solid state drive designed to enhance storage performance with a 2 TB capacity. Featuring Samsung V-NAND TLC Technology, this drive ensures high-speed data transfer with an internal data rate of 7250 MBps and a write speed of 6300 MBps, enabling seamless operation for demanding applications and large file management. With support for PCI Express 4.0 and 5.0 interfaces, it meets various system requirements while offering speed and reliability.
Designed with advanced features such as Intelligent TurboWrite Technology and an Auto Garbage Collection Algorithm, the Samsung 990 EVO Plus maintains efficiency and durability even under heavy workloads. Its shock and vibration resistance capability of up to 1500 g and a temperature range from -40°C to 85°C makes it suitable for both consumer and professional environments. This SSD ensures quick data access and provides hardware encryption for enhanced security, making it an ideal choice for users looking to upgrade system performance.
  • Efficient data transfer
    With internal data rates reaching up to 7250 MBps, data can be transferred swiftly, enabling faster boot times and quicker application load speeds.
  • High durability
    Featuring a shock resistance of up to 1500 g and a vibration tolerance, this drive is rugged enough to withstand physical stress, ensuring reliable operation in various environments.
  • Advanced performance management
    Supports TRIM, Auto Garbage Collection, and Device Sleep to optimize performance and extend the lifespan of the drive, making it suitable for both everyday use and demanding applications.
  • Enhanced security features
    Equipped with 256-bit AES hardware encryption and TCG Opal Encryption 2.0, the drive provides robust security measures to protect sensitive data from unauthorized access.
Samsung 990 EVO Plus MZ-V9S2T0 - SSD - 4 TB - PCIe 5.0 x2 (NVMe)
Solid state drive - internal
4 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
PCIe 5.0 x2 (NVMe)
Intelligent TurboWrite Technology, Samsung V-NAND TLC Technology, Device Sleep support, Host Memory Buffer (HMB), TRIM support, Auto Garbage Collection Algorithm, S.M.A.R.T., IEEE 1667
22.15 mm x 80.15 mm x 2.38 mm
9 g
5-year warranty
4 TB
Hardware Encryption
256-bit AES
M.2 2280
PCIe 5.0 x2 (NVMe)
22.15 mm
80.15 mm
2.38 mm
9 g
Performance
Internal Data Rate
7250 MBps (read) / 6300 MBps (write)
Maximum 4KB Random Write
1400000 IOPS
Maximum 4KB Random Read
1050000 IOPS
Reliability
MTBF
1.500.000 hours
Expansion & Connectivity
Compatible Bay
M.2 2280
Power Consumption
5.5 watt (read) , 4.8 watt (write) , 60 mW (standby) , 5 mW (sleep)
Software Included
Samsung Magician Software
Enclosure Material
Nickel coating
Shipping Width
9.9 cm
Shipping Depth
2.29 cm
Shipping Height
14.2 cm
Limited warranty - 5 years / 2400 TBW
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (non-operating)
20 g @ 20-2000 Hz
Capacity: 4TB
Brand: Samsung
Price Range Ex VAT: £500 - £750
