Samsung 9100 PRO, PCIe 5.0, NVMe M.2 SSD, 4TB
Quicklinx: J3T7WS00 Mfr#: MZ-VAP4T0BW
Form Factor: M.2 2280
Type: Solid state drive
Capacity: 4TB
27 In Stock
£954.23 ex VAT
£1,145.07 inc VAT
Samsung 9100 PRO solid state drive offers a 4 TB capacity, designed to enhance computing performance with speedy file access and storage. Operating within a temperature range of 0°C to 70°C, it ensures reliable performance under various conditions. The PCI Express 5.0 x4 (NVMe) interface, combined with Samsung's Intelligent TurboWrite 2.0 Technology, increases read and write speeds, reaching internal data rates of up to 14,800 MBps and 13,400 MBps respectively. The integrated heatsink maintains optimal operating temperatures, allowing for sustained performance even during demanding tasks. Additionally, the drive incorporates features such as TRIM support and Auto Garbage Collection Algorithm, ensuring longevity and maintaining speed over time. With a robust endurance rating of 2,400 TB, the Samsung 9100 PRO is built to handle intensive workloads while maintaining data integrity. The 256-bit AES hardware encryption provides added security for sensitive information, making this SSD a choice for professionals and gamers.
  • High performance
    The Samsung 9100 PRO delivers speed with internal data rates of 14,800 MBps for reading and 13,400 MBps for writing, ensuring quick access to large files and improved system responsiveness.
  • Robust endurance
    With a rated endurance of 2,400 TB, this SSD is designed to withstand heavy usage, making it suitable for demanding applications and environments.
  • Efficient thermal management
    Equipped with an integrated heatsink, the Samsung 9100 PRO maintains optimal temperatures during operation to prevent overheating and sustain performance.
  • Advanced security features
    Featuring 256-bit AES hardware encryption and supporting TCG Opal Encryption 2.0, this SSD ensures data protection and privacy for users handling sensitive information.
  • Reliable operating temperature range
    This solid state drive operates effectively between 0°C and 70°C, making it suitable for various environments and ensuring consistent performance under temperature fluctuations.
Samsung 9100 PRO MZ-VAP4T0 - SSD - 4 TB - PCI Express 5.0 x4 (NVMe)
Solid state drive - internal
4 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
TRIM support, Auto Garbage Collection Algorithm, Device Sleep support, Samsung V-NAND TLC Technology, integrated heatsink, Intelligent TurboWrite 2.0 Technology, PlayStation compatible, NVMe 2.0, S.M.A.R.T.
Enclosure Colour
22.15 mm x 80.15 mm x 2.38 mm
9 g
5-year warranty
4 TB
Hardware Encryption
256-bit AES
M.2 2280
22.15 mm
80.15 mm
2.38 mm
9 g
Performance
SSD Endurance
2400 TB
Internal Data Rate
14800 MBps (read) / 13400 MBps (write)
Maximum 4KB Random Write
2600000 IOPS
Maximum 4KB Random Read
2200000 IOPS
Reliability
MTBF
1.500.000 hours
Expansion & Connectivity
Compatible Bay
M.2 2280
Power Consumption
9 watt (read) , 8.2 watt (write) , 6.5 watt (idle) , 5.7 mW (sleep)
Software Included
Samsung Magician Software
IEEE 1667
Enclosure Colour
Package Details
Box
Limited warranty - 5 years / 2400 TBW
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms half-sine
Vibration Tolerance (non-operating)
20 g @ 20-2000 Hz
Capacity: 4TB
Brand: Samsung
Price Range Ex VAT: £750 - £1000
