Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
Samsung 990 PRO PCIe 4.0 NVMe M.2 4TB
Quicklinx: HDQ0WS00 Mfr#: MZ-V9P4T0BW
Form Factor: M.2 2280
Type: Solid state drive
Capacity: 4TB
£771.14 ex VAT
£925.36 inc VAT
Marketing description is not available.
  • Enhanced durability
    Equipped with Dynamic Thermal Guard protection, the Samsung 990 PRO ensures optimal performance by preventing overheating, alongside a robust shock and vibration tolerance that safeguards your data during unexpected jolts.
  • High-speed performance
    Boasting an impressive internal data rate of up to 7450 MBps for reading and 6900 MBps for writing, this solid state drive leverages PCI Express 4.0 x4 (NVMe) interface for swift data transfer, making it ideal for demanding applications and multitasking.
  • Advanced security
    With 256-bit AES hardware encryption and TCG Opal Encryption, the Samsung 990 PRO offers a secure storage solution, protecting sensitive data against unauthorized access.
  • Efficient operation
    Features like Device Sleep support and a low power consumption mode ensure the drive operates efficiently, reducing energy costs while maintaining high performance.
  • Large capacity and reliability
    A generous 4 TB capacity backed by a 1,500,000 hours MTBF rating, coupled with S.M.A.R.T. compliance, provides ample storage for extensive digital libraries with dependable longevity.
Samsung 990 PRO MZ-V9P4T0BW - SSD - 4 TB - PCIe 4.0 x4 (NVMe)
Solid state drive - internal
4 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Multi-level cell (MLC)
M.2 2280
PCIe 4.0 x4 (NVMe)
Samsung V-NAND 3bit MLC Technology, NVM Express (NVMe) 2.0, 4 GB Low Power DDR4 SDRAM Cache, TRIM support, Garbage Collection technology, Device Sleep support, Dynamic Thermal Guard protection, S.M.A.R.T.
22 mm x 80 mm x 2.3 mm
9 g
4 TB
Hardware Encryption
256-bit AES
M.2 2280
PCIe 4.0 x4 (NVMe)
22 mm
80 mm
2.3 mm
9 g
Performance
Internal Data Rate
7450 MBps (read) / 6900 MBps (write)
Maximum 4KB Random Write
1550000 IOPS
Maximum 4KB Random Read
1600000 IOPS
Reliability
MTBF
1,500,000 hours
Expansion & Connectivity
Compatible Bay
M.2 2280
Power Consumption
5.5 watt (average) , 55 mW (idle)
Software Included
Samsung Magician Software
IEEE 1667
70 °C
Shock Tolerance (operating)
0.5 ms half-sine
Shock Tolerance (non-operating)
1500 g
Capacity: 4TB
Brand: Samsung
Price Range Ex VAT: £750 - £1000
