Samsung 2TB SpinPoint EcoGreen F4EG SATA 3Gb/s 32MB Hard Drive
2TB
Quicklinx: 74TDWS00 Mfr#: HD204UI/ST2000DL004
The NEW Samsung EcoGreen F4
667GB Formatted Capacity Per Disk (3 platters on this disk) Environment friendly product with RoHS compliance. Improved performance with dual-ARM based firmware. Improved recording stability over temperature with PMR ATA S.M.A.R.T. Compliant Advanced dynamic FOD control for best data integrity. ATA Automatic Acoustic Management Feature. Intelligent compensation of external disturbance. ATA 48-bit Address Feature. SATA Native Command Queuing Feature. ATA Device Configuration Overlay Feature Device Initiated
  • 667GB Formatted Capacity Per Disk (Disk has 3 platters)
  • Serial ATA 3.0Gbps Interface Support
  • Improved recording stability over temperature with PMR
  • Advanced dynamic FOD control for best data integrity
  • Intelligent compensation of external disturbance
  • SATA Native Command Queuing Feature
  • Device Initiated SATA Power Management
  • Shock & Rotational vibration sensor
  • Environment friendly product with RoHS compliance
  • Improved performance with dual-ARM based firmware
  • ATA S.M.A.R.T. Compliant
  • ATA Automatic Acoustic Management Feature
  • ATA 48-bit Address Feature
  • ATA Device Configuration Overlay Feature
  • NoiseGuard™
  • SilentSeek™
Drive Configurations
  • Interface: Serial ATA 3.0Gbps
  • Buffer DRAM Size: 32 MB
  • Byte per Sector: 4K Sector with Emulation
Performance Specifications
  • Average Seek time(typical): 8.9 ms
  • Data Transfer Rate / Media to/from Buffer(Max.): 250MB/sec
  • Data Transfer Rate / Buffer to/from Host(Max.): 300MB/sec
  • Average Latency: 5.52 ms
  • Drive Ready Time(typical): 13 sec
Reliability Specifications
  • Non-recoverable Read Error: 1 sector in 1015bits
Acoustics
  • Idle: 2.5/2.6 Bel
  • Performance Seek: 2.8/2.9 Bel
Environmental Specifications
  • Temperature / Operating 0 ~ 60 °C
  • Temperature / Non-operating -40 ~ 70 °C
  • Humidity(non-condensing) / Operating 5 ~ 95 %
  • Humidity(non-condensing) / Non-operating 5 ~ 95 %
  • Liner Shock(1/2 sine pulse) / Operating 70 G
  • Liner Shock(1/2 sine pulse) / Non-operating 300 G
  • Altitude(relative to sea level) / Operating -1,000 to 10,000 ft
  • Altitude(relative to sea level) / Non-operating -1,000 to 40,000 ft
Power Requirements
  • Voltage +5V±5%, +12V±10%
  • Spin-up Current (Max.) 2.0A
  • Seek (typical) 5.7W
  • Read/Write (typical) 6.3W
  • Idle (typical) 5.1W
  • Standby (typical) 1W
  • Sleep (typical) 1W
Physical Dimension
  • Height (Max.) 26.1 mm
  • Width 101.6 mm
  • Length 147.0 mm
  • Weight (avg.) 650g
3.5"
Hard drive
Interface Type
Serial ATA-300
2 TB
Spin Speed (rpm)
5400 rpm
