Samsung 250GB 840 Series SATA 6Gb/s 2.5" Solid State Drive
Quicklinx: 8BNXWS00 Mfr#: MZ-7TD250BW
The Samsung 840 is a high performance SSD designed for power users. Capable of delivering up to 98,000 IOPS Random Read Speed and 540MB/s Sequential Read speed, it is an SSD of unrivaled high performance. Even better, the advanced MDX controller delivers these speeds regardless of data type, unlike some competing controllers that greatly favor compressible data.
  • Capacity: 250GB
  • Sequential Read: 540MB/s
  • Sequential Write: 250MB/s
  • Random Read (QD32, 4KB): 96,000 IOPS
  • Random Write (QD32, 4KB): 62,000 IOPS
  • Random Read (QD1, 4KB): 7,900 IOPS
  • Random Write (QD1, 4KB): 29,000 IOPS
  • Warranty: 3 Year
  • The single best upgrade for your PC
    With its simple 3-Step migration solution and industry-leading IOPS performance, the Samsung SSD 840 Series is the single best upgrade you can make for your PC. Samsung's SmartMigration software takes the guesswork and headache out of moving your operating system and precious data to your new SSD. Once you're up and running, the 840 Series' amazing IOPS speeds empower you to multitask like never before. Upgrading to an SSD is the easiest and most economical way to breathe new life into an aging PC. Today, most PC performance woes are the result of slow read and write speeds on behalf of the main storage device, not a lack of CPU performance. Upgrading to a Samsung SSD 840 Series can breathe new life into your old PC by enhancing boot-up speed, application loading, and multi-tasking performance.
  • Superior reliability
    Samsung SSDs are designed and built completely in-house. The Samsung SSD 840 Series is optimized for exceptional, sustained performance and unrivaled reliability through its specially-engineered wear-leveling and garbage collection algorithms.
  • Magician software
    Samsung's Magician software has been completely redesigned with an extreme focus on usability. Magician makes it simple for users to maximize the performance and lifetime of their Samsung SSD. In addition, SSD Magician also provides system information and facilitates performance benchmarking, performance optimization, OS optimization, firmware updates, secure erasing, and over provisioning. Drive Health Status, Total Bytes Written (TBW), and Disk Scan & Error Reporting functionality make Magician one of the most useful storage utilities available.
Samsung 840 Series MZ-7TD250 - SSD - 250 GB - SATA 6Gb/s
Solid state drive - internal
250 GB
2.5" Ultra Slim Line
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, Secure Erase function, Garbage Collection technology, S.M.A.R.T.
69.85 mm x 100 mm x 7 mm
63.5 g
3-year warranty
250 GB
SATA 6Gb/s
69.85 mm
100 mm
7 mm
63.5 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 240 MBps (write)
4KB Random Read
95000 IOPS
4KB Random Write
44000 IOPS
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
Software Included
Drivers & Utilities, Samsung Smart Migration Software, Samsung Magician Software 4.0
Linux, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits) SP2
Limited warranty - 3 years
60 °C
5 - 95% (non-condensing)
Shock Tolerance
1500 g @ 0.5ms (non-operating)
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 3.08 g @ 7-800 Hz (non-operating)
Resources
The following resources are available for the Samsung 250GB 840 Series SATA 6Gb/s 2.5" Solid State Drive
