Ergonomic gaming experience
With slimmer keycaps and shorter switches, enjoy natural hand positioning with a low-profile ergonomic gaming keyboard that allows for long hours of use with little strain. -
Clicky keystrokes with a soft, cushioned touch
Fusing the snappy, clicky feedback of a mechanical switch with the familiar feel of a conventional keyboard, each keystroke you make is as satisfying as it is precise. -
Improved fade and scratch resistance
More durable than regular keycaps, the UV coating ensures more fade-resistant legends and greater protection against wear and tear from frequent use. -
Convenient control
Configure them to pause, play, skip and adjust everything from brightness to volume - the ultimate convenience as you enjoy your entertainment. -
Extended gaming support
Designed to seamlessly snap to the low-profile keyboard, the soft-touch wrist rest provides ample comfort and support for your wrists - especially vital for long periods of use. -
Customizable lighting
With 16.8 million colors and a suite of RGB effects to choose from, personalize the keyboard and get access to dynamic lighting effects for hundreds of Chroma-integrated games.
- Razer Ornata V3 - keyboard - low profile - QWERTY - UK Input Device
- Keyboard
- Backlit
- 10 zone RGB
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Multimedia, programmable, macros buttons
- Protection
- Spill-resistant
- Numeric Keypad
- Gaming
- 2-year warranty
- Keyboard
- Backlit
- 10 zone RGB
- Interface
- USB
- Input Device
- Low profile
- Hot Keys Function
- QWERTY UK
- Keyboard Technology
- Mecha-membrane
- Gaming
- Adjustable Height
- Palm Rest
- Protection
- Spill-resistant
- Numeric keypad
- Included Software
- Razer Synapse
- Limited warranty - 2 years
