Mean performance in a leaner form - enter the Razer BlackWidow V3 Tenkeyless. Continuing an iconic legacy, this compact gaming keyboard is armed with Razer mechanical switches and powered by Razer Chroma RGB, for a level of precision and personalization beloved by gamers worldwide.
Full mechanical keys for superior tactility and faster response
The Razer BlackWidow's mechanical key technology provides a distinctive tactile feedback in form of a light pronounced tap to your fingers giving you an entirely new feel on your keyboard. With its optimised actuation force and a reduced actuation distance, the Razer BlackWidow's keys allow you to actuate your commands faster than on any other standard gaming keyboard. -
On-the-fly macro recording and profiles allow effortless configuration
Record unlimited macros on-the-fly without having to take your eye off the game and immediately change between up to 10 profiles without the hassle of going into complex driver menus. With the simple click of two buttons you initiate and end the recording and you're all set. -
Macro-keys and gaming mode ensure uninterrupted gaming experience
Expand the amount of easy-to-reach commands with the additional 5 macro keys on the side and avoid any distractions by switching on the gaming mode.
- Razer BlackWidow V3 Tenkeyless - keyboard - UK Input Device
- Keyboard
- Backlit
- RGB Chroma
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Hot Keys Function
- Programmable
- Key Switch Type
- Razer Green
- 2-year warranty
- Keyboard
- Backlit
- RGB Chroma
- Interface
- USB
- Hot Keys Function
- Programmable
- UK
- Keyboard Technology
- Mechanical
- Key Switch Type
- Razer Green
- Anti-ghosting
- Key Life Span
- 80 million clicks
- Included Software
- Razer Synapse 3
- Limited warranty - 2 years
