Razer Ornata V3 Tenkeyless - UK Layout
Quicklinx: HRJ2WS00 Mfr#: RZ03-04880300-R3W1
Wired / Wireless: Wired
Compatibility: PC
Hurry, only 2 left in stock!
£56.90 ex VAT
£68.28 inc VAT
Meet the Razer Ornata V3 - a low-profile ergonomic gaming keyboard powered by Razer Chroma RGB. Sporting an ultra-slim form factor, more durable keycaps, and unique mecha-membrane switches, enhance your work and play with a hybrid keyboard that combines the best of both worlds.
  • Ergonomic gaming experience
    With slimmer keycaps and shorter switches, enjoy natural hand positioning with a low-profile ergonomic gaming keyboard that allows for long hours of use with little strain.
  • Clicky keystrokes with a soft, cushioned touch
    Fusing the snappy, clicky feedback of a mechanical switch with the familiar feel of a conventional keyboard, each keystroke you make is as satisfying as it is precise.
  • Improved fade and scratch resistance
    More durable than regular keycaps, the UV coating ensures more fade-resistant legends and greater protection against wear and tear from frequent use.
  • Convenient control
    Configure them to pause, play, skip and adjust everything from brightness to volume - the ultimate convenience as you enjoy your entertainment.
  • Extended gaming support
    Designed to seamlessly snap to the low-profile keyboard, the soft-touch wrist rest provides ample comfort and support for your wrists - especially vital for long periods of use.
  • Customizable lighting
    With 16.8 million colors and a suite of RGB effects to choose from, personalize the keyboard and get access to dynamic lighting effects for hundreds of Chroma-integrated games.
Razer Ornata V3 - keyboard - tenkeyless - QWERTY - UK Input Device
Keyboard
Backlit
RGB Chroma
USB
Wired
Localization and Layout
QWERTY UK
Hot Keys Function
Multimedia, programmable
Protection
Spill-resistant
Gaming
36.3 cm x 14.4 cm x 3.1 cm
644 g
Keyboard
Backlit
RGB Chroma
USB
Input Device
Tenkeyless
Hot Keys Function
QWERTY UK
Keyboard Technology
Mecha-membrane
Anti-ghosting
Gaming
Palm Rest
Protection
Spill-resistant
36.3 cm
14.4 cm
3.1 cm
644 g
Included Software
Razer Synapse 3
Compatibility: PC
Brand: Razer
