Razer Basilisk V3
Razer Basilisk V3
Quicklinx: GX1FWS00 Mfr#: RZ01-04000100-R3M1
Recommended Use: Gaming
Type: Mouse
Wired / Wireless: Wired
Colour: Black
23 In Stock
£58.33 ex VAT
£69.99 inc VAT
Create, control, and champion your playstyle with the Razer Basilisk V3 - the quintessential ergonomic gaming mouse for adjusted performance. With 10+1 programmable buttons, an intelligent scroll wheel, and a heavy dose of Razer Chroma RGB, it's time to light up the competition your way.
  • Play it your way, like never before
    Assign all your macros and secondary functions across 11 easy-access buttons - including its acclaimed multi-function trigger - to execute essential actions like push-to-talk, ping, and more.
  • High-profile performance
    Seamlessly switch between any of your custom button profiles via a programmable button underneath the mouse for optimized performance with every game and task.
  • Perfecting scrolling: Razer HyperScroll Tilt Wheel
    The recent scroll wheel innovation offers another level of functionality you can definitely put a finger on. Offering two types of scrolling for more flexibility, it can also toggle automatically between them for truly seamless use thanks to an outstanding intelligent function.
  • Virtual acceleration
    By turning on this Razer Synapse feature, you'll be able to increase the mouse's scroll speed the faster you scroll, allowing you to navigate through lengthy documents and articles at an even quicker rate.
  • RGB that's off the charts: 11 Razer Chroma RGB lighting zones
    Bask in the Razer Basilisk V3's glory as you adapt each zone from over 16.8 million colors and countless lighting effects, all while it reacts dynamically with over 150 Chroma-integrated games.
  • Razer optical mouse switches Gen-2
    With switches that clock in at a blistering 0.2ms actuation speed for up to 70 million clicks, you can expect nothing but crisp, responsive execution with zero misclicks.
  • RAZER Focus+ 26K DPI Optical Sensor
    Enjoy responsive, pixel-precise aim with an improved sensor that flawlessly tracks your movement with zero spinouts.
  • Iconic ergonomic design with thumb rest
    Favored by millions worldwide, the mouse's ergonomic form factor perfectly supports your hand while its buttons are optimally positioned for quick and easy access.
  • 5 on-board memory profiles
    Be ready to compete anywhere with access to your custom key-binds, DPI, and twice the inputs via the Razer HyperShift function.
  • 100% PTFE mouse feet
    This gaming mouse glides smoothly across any surface with mouse feet made from the pure, high-grade PTFE.
Razer Basilisk V3 - mouse - USB
Mouse - ergonomic
Wired - USB
Orientation
Right-handed
6 cm x 13 cm x 4.25 cm
101 g
Movement Detection Technology
Optical
Buttons Qty
11
Movement Resolution
26000 dpi
Performance
70 million clicks, 650 inches per second, 50 G maximum acceleration
Scrolling wheel, programmable buttons, tiltable scroll wheel, RGB 16.8 millions multi-colour illumination, Razer Focus+ Optical Sensor
Mouse
Ergonomic Design
Orientation
Right-handed
6 cm
13 cm
4.25 cm
101 g
Input Device
Wired
USB
Optical
Buttons Qty
11
Movement Resolution
26000 dpi
Performance
Type: Mouse
Colour: Black
Brand: Razer
