Razer Naga Trinity Mouse
Quicklinx: FVDSWS00 Mfr#: RZ01-02410100-R3M1
Experience the power of total control in your hand, no matter what game you play. Designed to provide you that edge you need in MOBA/MMO gameplay, the Razer Naga Trinity lets you configure your mouse for everything from weapons to build customizations so you'll always be ahead of the competition.
The Razer Naga Trinity is equipped with three interchangeable side plates that allow you to switch between two, seven and twelve-button configurations, depending on your in-game needs. With a 16,000 DPI 5G optical sensor, mouse movements are swift and executed exactly. Also, get access to even more commands with up to 19 programmable buttons.
Designed with an enhanced right-handed form factor for comfort and well-positioned buttons for easy actuation, you can game for long hours without feeling the strain.
  • Incredibly deft, deadly accurate
    Equipped with an advanced 5G optical sensor, the Razer Naga Trinity is optimized for precision and speed, ensuring movements are swift, your spells are on target, and that you get out of the fire when battles turn intense.
  • More ways to customize
    With interchangeable side plates for 2, 7 and 12-button configurations, transmute your mouse to suit your gameplay. Each button is designed to stand out so you'll never misclick, providing tactile and audible feedback so you'll be assured of every actuation.
  • Ready up for more action
    The more buttons you have instant access to, the greater your advantage becomes. With programmable buttons, be spoilt for choice whether you're assigning just the essentials or going full-out to bind item hotkeys, spells or any other in-game commands you need.
Razer Naga Trinity - mouse - USB
Mouse
Wired - USB
Orientation
Right-handed
7.4 cm x 11.9 cm x 4.3 cm
120 g
Movement Detection Technology
Laser
Buttons Qty
17
Movement Resolution
16000 dpi
Performance
50 G maximum acceleration, polling rate: 1000 Hz, 450 inches per second
Programmable buttons, illuminated scrolling wheel, interchangeable side panels, 16.8 million multi-colour illumination, Chroma lighting system, 5G laser sensor, Razer mechanical switches, Razer Synapse 3 (beta) enabled
2 Years
Mouse
Orientation
Right-handed
7.4 cm
11.9 cm
4.3 cm
120 g
Input Device
Wired
USB
Laser
Buttons Qty
17
Movement Resolution
16000 dpi
Performance
1 x USB - 4 pin USB Type A
3 interchangeable side panels
2 Years
