Brand
Razer Hammerhead True Wireless x
Quicklinx: GK9FWS00 Mfr#: RZ12-03830100-R3G1
Recommended Use: Portable electronics
Connectivity: Wireless
More than 50 in stock
£29.17 ex VAT
£35.00 inc VAT
Express delivery Delivered on Tuesday
The Razer Hammerhead in-ear headphones are in-ear monitors (IEM) engineered from the ground up to set the standard in portable gaming audio. Machined out of aircraft grade aluminum, the Razer Hammerhead embodies ultimate durability packaged in a lightweight, comfortable form factor.
Encased within each sleek, brushed shell is a high performance, precision-tuned 9 mm neodymium driver. Paired with an optimized inner acoustics chamber in each shell, these in-ear monitors produce a sound signature that packs a mean, earth-shattering bass while maintaining crystal clear mids and highs. The Razer Hammerhead comes through with a full-bodied low-end frequency, pounding in the beats without distortion. The Razer Hammerhead epitomizes the way in-ear monitors should be experienced - with style, comfort and aural fidelity.
LIGHT IT UP
Light it up with the Razer Hammerhead True Wireless X—high-performance earbuds engineered to illuminate. Packing a 60ms low latency Gaming Mode along with custom-tuned 13mm drivers, brace yourself for audio that rises above the noise.
60MS LOW LATENCY GAMING MODE
Activate Gaming Mode to fire up the Razer Hammerhead True Wireless X’s leading performance while gaming on Bluetooth devices for a more seamless and lag-free experience
MOBILE APP CUSTOMIZATION
Maximize your earbuds with the Razer Audio app. Remap touch gestures, customize the EQ, and get continuous improvements with over-the-air firmware updates
WATER RESISTANT DESIGN
Because the earbuds are water-resistant, you can work out to your favorite tunes and have the freedom to wear them in a variety of outdoor activities
BLUETOOTH 5.2 WITH AUTO-PAIRING
Endowed with the increased bandwidth, range, and energy efficiency of Bluetooth 5.2, the earbuds last longer and automatically connect to their last paired device for easy handling.
GOOGLE FAST PAIR
During initial setup, conveniently pair your Razer Hammerhead True Wireless X with Bluetooth capable Android devices with a single tap of a pop-up notification
TOUCH-ENABLED CONTROLS
Control your music and calls, enable Gaming Mode, and activate your smartphone’s voice assistant—all with a few easy taps.
QUICK SPECS
• 60ms low latency Gaming Mode
• Mobile app customization
• Custom-tuned 13mm drivers
• Bluetooth 5.2 with Auto-Pairing
• Google Fast Pair
• Touch-enabled controls
  • Enhanced bass with superior clarity
    The inner acoustics chambers of the Razer Hammerhead feature a sonically optimized design to increase aural resonance. Together with the high performance, precision-tuned 9 mm neodymium drivers, the headset produces a sound signature that packs a strong bass while maintaining crystal clear mids and highs. Experience full-bodied low-end frequencies without annoying distortion to your beats.
  • Machined lightweight aluminum body
    The Razer Hammerhead is machined out of aircraft grade aluminum, promising extreme durability while maintaining a lightweight, comfortable form factor. With a matte, brushed surface finish, these in-ear monitors look as good as they sound.
Razer Hammerhead True Wireless X - true wireless earphones with mic
True wireless earphones - Bluetooth
Recommended Use
Additional Functions
LED backlight (green)
Headphones Form Factor
In-ear
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 5.2
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 91 dB/mW
Impedance
32 Ohm
Max Input Power
8 mW
Microphone Operation Mode
Omni-directional
2 Years
True wireless earphones - Bluetooth - wireless
Dimensions & Weight Details
Earbud: 10 g , Charging case: 42 g
Recommended Use
Audio Output
In-ear
Wireless
Wireless Technology
Bluetooth
Bluetooth Audio Codec
SBC, AAC
Bluetooth Version
Bluetooth 5.2
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Max Input Power
8 mW
Sensitivity
91 dB/mW
Impedance
32 Ohm
Diaphragm
13 mm
Microphone
Built-in
Omni-directional
Sensitivity
-26 dBFS
Signal-To-Noise Ratio
64 dB
Charging case
Headphone battery rechargeable
Run Time (Up To)
7 hour(s)
Run Time Details
Continuous playback: up to 7 hours , Continuous playback (with included charging case): up to 28 hours
2 Years
Brand: Razer
Stock Status: Clearance
