Feel complete immersion without feeling the weight - introducing the Razer Kraken V3 X, a USB PC gaming headset that allows you to game on, and on, and on. Upgraded with patented Razer TriForce drivers for incredibly realistic sound, it's time to lose yourself with an audio experience that's always a win.
                Ultra-light comfortAlready at an airy 285g, this PC gaming headset's slim form factor is supported by a trio of design elements that make it feel like it weighs even less.
                Hybrid fabric and memory foam ear cushionsPlush, breathable cushioning that keeps your ears comfy during gaming marathons.
                Soft headband paddingRelieves pressure on your head when wearing the headset for long periods of time.
                Measured fitThe headset applies just the right amount of force for a fit that's firm yet comfortable.
                Razer TriForce 40mm driversHear your game truly come to life with high-fidelity audio that doesn't muddy. Enjoy richer trebles, brighter sound, and more powerful bass with patented 3-part audio driver design that focuses on high, mid, and low audio frequencies separately.
                7.1 surround soundHeighten your immersion and let nothing escape your ears with accurate positional audio that lets you easily discern where every sound is coming from.
                Razer Hyperclear cardioid micOffering greater speech pickup and noise cancellation, the bendable mic on this PC gaming headset ensures improved clarity and a natural representation of your voice.
                Powered by Razer Chroma RGBWith 16.8 million colors, countless patterns, dynamic in-game lighting effects - experience full RGB customization and deeper immersion with the world's largest lighting ecosystem for gaming devices. Supporting a growing list of thousands of devices and hundreds of games & applications, take it to the next level with advanced features such as Chroma Studio, Visualizer, Connect and Workshop.
                Convenient audio controlTweak and toggle settings easily with a microphone mute button and volume slider located underneath its left earcup.
- Razer Kraken V3 X - Fortnite Edition - headset
- Product Type
- Headset
- Recommended Use
- Game console, computer
- Gaming
- Style
- Games
- Headphones Form Factor
- Full size
- Sound Effects
- Virtual surround sound
- Audio Specifications
- Frequency Response 12 - 28000 Hz - Sensitivity 103 dB
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional (HyperClear flexible cardioid)
- Controls
- Mute, volume
- Product Type
- Headset
- Style
- Games
- Dimensions & Weight Details
- Inner earcup diameter: 4 cm x 6 cm
- 285 g
- Earpad Material
- Memory foam, hybrid fabric
- Recommended Use
- Gaming
Audio Output
- Full size
- Sound Effects
- 12 - 28000 Hz
- Sensitivity
- 103 dB
- Impedance
- 32 Ohm
- Diaphragm
- 40 mm
- Magnet Material
- Razer TriForce
- Razer Chroma RGB
Microphone
- Boom
- Form Factor
- Headset microphone
- Sensitivity
- -42 dB
- Sensitivity Margin
- +/- 3dB
- 100 - 10000 Hz
- Noise Cancelling Technology
- Razer HyperClear
Remote Control
- Controls
- Mute, volume
- Connector Type
- USB (4 PIN USB Type A)
Cable
- Cable Length
- 1.8 m
- Cable Details
- USB-A cable - 1.8 m
