Razer Kraken V4 X
Razer Kraken V4 X
Quicklinx: HTJLWS00 Mfr#: RZ04-05180100-R3M1
Recommended Use: Game console, Computer
Connectivity: Wired
£74.45 ex VAT
£89.34 inc VAT
Razer TriForce 40 mm Drivers - for powerful, lifelike audio
Our patented 3-part driver design pushes out exceptional highs, mids and lows that doesn’t muddy, providing a more dynamic listening experience for deeper immersion.
Retractable Razer HyperClear Cardioid Mic - for enhanced voice capture
The mic’s improved pickup pattern ensures more voice and less noise, while its retractable design allows for optimal positioning or protection when not in use.
Surround Sound - for realistic positional sound
With our advanced 7.1 surround sound, enjoy true-to-life acoustics that optimizes your game’s sound design so you can hear everything as if you were right in the middle of it all.
Hybrid Fabric and Leatherette Memory Foam Cushions - for All-Day Comfort and Noise Isolation
The snug, close-fitting earcups provide superior sound isolation and comfort, allowing you to game for hours in complete, uninterrupted immersion.
Convertible Type C & Type A Cable - for multi-platform versatility
Enjoy immersive audio for all your favorite platforms with just a single headset - Switch between your PC, console, phones and more with a convertible Type C and Type A cable.
Powered by Razer Chroma RGB - for greater customization
With access to 16,8 million colors and a suite of lighting effects, apply your preferred settings and watch it work seamlessly with over 300 games and 500 devices across more than 50 partners.
  • Designed for maximum comfort and durability
    The construction of the Razer Kraken had a singular motivation - durability to withstand daily abuse on the go, whether they are tuning out your daily commute or providing the soundtrack while you hit the slopes. Their light-weight design makes these headphones comfortable for hours on end.
  • Foldable ear cups for maximum portability
    The ear cups of the Razer Kraken are foldable, making the footprint of these full-sized headphones extremely compact for maximum mobility so you can take them along anywhere you go.
  • Large 40mm Neodymium drivers for powerful audio
    The Razer Kraken is outfitted with large 40mm neodymium magnet drivers tuned for crystal clear music in the high-and mid-ranges and packing deep bass for powerful lows, making them versatile music and gaming headphones.
Razer Kraken V4 X - headset - USB-C
Headset - wired - USB-C
Compatibility
Windows, Mac
Recommended Use
Computer, Game console
Gaming
Headphones Form Factor
Full size
Wired
Sound Effects
7.1 Channel Virtual Surround Sound
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 96 dB
Impedance
32 ohm
Noise Isolating
Microphone
Boom
Microphone Operation Mode
Uni-directional (HyperClear cardioid)
Controls
Volume, microphone on/mute
Compatibility
Windows, Mac
Dimensions & Weight Details
Inner earcup diameter: 4.2 cm x 6.2 cm
300 g
Earpad Material
Memory foam, breathable fabric
Recommended Use
Gaming
Audio Output
Full size
Headphones Cup Type
Closed
Wired
Sound Effects
Noise Isolating
Frequency Response
20 - 20000 Hz
Sensitivity
96 dB
Impedance
32 ohm
Diaphragm
40 mm
Magnet Material
Razer TriForce
Razer Chroma RGB
Microphone
Boom
Headset microphone
Sensitivity
-42 dB
Sensitivity Margin
+/- 3dB
Frequency Response
100 - 10000 Hz
Retractable microphone
Remote Control
Controls
Connector Type
USB (24 pin USB-C)
Cable
Cable Length
1.8 m
USB-A to USB-C adapter
Cable Details
USB-C cable - 1.8 m
Supported Host Device OS
iOS, Android, Windows, macOS
Recommended Use: Computer
Connectivity: Wired
Brand: Razer
