Razer Kraken V3 Hypersense
Quicklinx: HLNLWS00 Mfr#: RZ04-03770100-R3M1
Recommended Use: Computer, Game console
Connectivity: Wired
Earcover : Binaural
£99.17 ex VAT
£119.00 inc VAT
Dive into a new dimension of immersion with the Razer Kraken V3 HyperSense - a PC gaming headset powered by haptic technology. From rumbling explosions to whizzing bullets, with the ability to feel what you hear, the time has come to embrace true multi-sensory gaming.
  • Razer HyperSense
    Cutting-edge haptic drivers in each earcup pick up on audio cues and convert them into realistic vibrations that vary in position, duration, and intensity, providing touch-sensory feedback for in-game sounds.
  • Stereo haptics
    Haptic effects flow between left and right earcups based on in-game positioning for greater spatial awareness and immersion.
  • Real-time haptics
    Intelligent audio processing that requires zero integration or additional downloads to work. Compatible across games, music, and movies.
  • Intensity adjuster
    Easily adjust the haptics' strength with an on-headset button that can toggle between off, low, medium, and high.
  • THX spatial audio
    The headset is armed with advanced 7.1 surround sound that optimizes your game's sound design for realistic positional audio. Experience true-to-life acoustics and hear everything as if you were right in the middle of it all.
  • Razer TriForce titanium 50mm drivers
    The patented 3-part driver design pushes out exceptional highs, mids, and lows that doesn't muddy, providing a more dynamic listening experience for deeper immersion. Upgraded with titanium-coated diaphragms for superior clarity, the drivers enable truly lifelike and accurate sound reproduction.
  • Hybrid fabric and leatherette memory foam cushions
    The perfect balance of comfort, sound isolation, and haptics transfer.
  • Razer hyperclear cardioid mic
    By suppressing sounds from the back and sides, the detachable mic offers greater speech pickup and noise cancellation, ensuring improved clarity and a natural representation of your voice.
  • Powered by Razer Chroma RGB
    With 16.8 million colors and a suite of effects, enjoy greater immersion as it dynamically reacts with over 150 integrated games. Hold down the Razer HyperSense adjuster button to conveniently cycle through Razer Chroma RGB lighting effects.
Razer Kraken V3 HyperSense - headset - USB-A
Headset - wired - USB-A
Recommended Use
Additional Functions
RGB lighting
Style
Games
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Sound Effects
THX Spatial Audio
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 96 dB
Impedance
32 Ohm
Noise Isolating
Microphone
Boom
Microphone Operation Mode
Uni-directional (super-cardioid)
Controls
Volume, microphone on/mute
RGB lighting
Style
Games
27 cm
15 cm
28 cm
344 g
Earpad Material
Memory foam, leatherette
Recommended Use
Audio Output
Full size
Wired
Sound Output Mode
Stereo
Sound Effects
THX Spatial Audio
Noise Isolating
Frequency Response
20 - 20000 Hz
Sensitivity
96 dB
Impedance
32 Ohm
Diaphragm
50 mm
Magnet Material
Razer Triforce titanium
Razer HyperSense, Razer Chroma RGB
Microphone
Boom
Headset microphone
Sensitivity
-42 dB
Sensitivity Margin
+/- 3dB
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A)
Cable
Cable Length
2 m
Cable Details
USB cable - 2 m
Recommended Use: Game console
Connectivity: Wired
Earcover : Binaural
Brand: Razer
