Ultra-fast, ultra-reliable actuation
Armed with the same lightning-fast response that's a hallmark of all optical keyboards, perform quicker keystrokes with switches that have a shorter actuation height for reduced key travel. -
Ultra-low-latency gaming
Experience ultra-low-latency gaming with the 2.4 GHz connection that's even faster. -
Versatile and convenient
Use the wireless keyboard on your PC, tablet, and more, as you seamlessly switch between devices. -
Non-stop use
With impressive power efficiency to support its optical switches and bright RGB backlight, the Razer DeathStalker V2 Pro has a long battery life. -
Long-lasting ergonomics
The keyboard's slim profile ensures neutral hand positioning for long hours of use with little strain, while its aluminum alloy top plate provides greater durability with a satisfying heft. -
Convenient control
Configure them to pause, play, skip and tweak everything from brightness to volume - the ultimate convenience as you enjoy your entertainment.
- Razer DeathStalker V2 Pro - keyboard - QWERTY - UK Input Device
- Keyboard - ergonomic
- Backlit
- RGB
- Interface
- 2.4 GHz, Bluetooth 5.0
- Connectivity Technology
- Wireless
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Multimedia, programmable
- Protection
- Scratch-resistant
- Key Switch Type
- Linear
- Case Material
- 5052 aluminium alloy
- 2-year warranty
- Backlit
- RGB
- Interface
- Wireless
- Hot Keys Function
- QWERTY UK
- Key Switch Type
- Linear
- Protection
- Scratch-resistant
Carrying Case
- Material
- Key Life Span
- 70 million clicks
- Included Software
- Razer Synapse, Gaming Mode
- Limited warranty - 2 years
