When it comes to the competition, it's time to make a killer statement. Deliver deadly performance and show no mercy with best-in-class ergonomics combined with next-generation sensor and switches.
- Best-in-class ergonomics
- Razer Optical Mouse Switches
- Razer Focus+ Optical Sensor
- Razer Speedflex Cable
- Advanced on-board memory
Best-in-class ergonomic shape
Through countless prototyping and testing, our ergonomics scientists and designers have created the most comfortable, lightweight build that allows you to game at your best, and for longer. -
Razer optical mouse switch
Every click you make is actuated at the speed of light with no debounce delay so you'll always be the first to pull the trigger. The switches are also durable for up to 70 million clicks. -
Razer Focus+ 20K optical sensor
A 20,000 DPI optical sensor ensures that even the finest movement of your mouse is tracked, giving you an acute level of precision for game-winning headshots and highly elusive manoeuvres. -
Razer Speedflex cable
Featuring greater flexibility and minimal drag for unhindered swipes, allowing for smooth control during your matches. -
5 on-board memory profiles
Save up to 5 profile configurations into the on-board memory and bring your settings anywhere so you're always ready to compete with your preferred controls. -
8 programmemable buttons
The mouse comes with 8 programmemable buttons that are fully configurable via Razer Synapse 3, giving you access to macros and secondary functions so every action can be executed with ease.
- Razer DeathAdder V2 - mouse - USB
- Mouse - ergonomic
- Connectivity Technology
- Wired - USB
- Orientation
- Right-handed
- 6.17 cm x 12.7 cm x 4.27 cm
- 82 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 8
- Movement Resolution
- 20000 dpi
- Performance
- 50 G maximum acceleration, 650 inches per second, 70 million clicks, realtime sensitivity switching 400/800/1600/2400/3200 dpi
- Scrolling wheel, programmable buttons, Razer Synapse 3 enabled, RGB 16.8 millions multi-colour illumination
- Cable Length
- 2.1 m
- 2-year warranty
- Mouse
- Ergonomic Design
- Orientation
- Right-handed
- 6.17 cm
- 12.7 cm
- 4.27 cm
- 82 g
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 8
- 20000 dpi
- Performance
- Cable Length
- 2.1 m
- Limited warranty - 2 years
