Full Mechanical Keys for Superior Tactility and Faster Response
The Razer BlackWidow's mechanical key technology provides a distinctive tactile feedback in form of a light pronounced tap to your fingers giving you an entirely new feel on your keyboard. With its optimized actuation force of 50g and a reduced actuation distance of 2 mm the Razer BlackWidow's keys allow you to actuate your commands faster than on any other standard gaming keyboard.
On-The-Fly Macro Recording & Profiles allow Effortless Configuration
Record unlimited macros on-the-fly without having to take your eye off the game and immediately change between up to 10 profiles without the hassle of going into complex driver menus. With the simple click of two buttons you initiate and end the recording and you're all set
Individually Backlit Keys
Never miss a key in the dark with backlit keys that give you the tactical edge, allowing you to launch assaults and flank your foes even under low light conditions.
TECH SPECS
Full mechanical keys with 50g actuation force
Individually backlit keys
1000Hz Ultrapolling / 1ms response time
Programmable keys with on-the-fly macro recording
Gaming mode option for deactivation of the Windows key
10 customizable software profiles with on-the-fly switching
5 additional macro keys
Gaming optimized key matrix for minimized ghosting
Multi-Media Controls
Braided fibre cable
Audio-Out / Mic-In Jacks
USB-Passthrough
Approximate Size : 475 mm / 18.70" (Width) x 171 mm / 6.73" (Height) x 30 mm / 1.18" (Depth)
Approximate Weight: 1500 g / 3.31 lbs
Full mechanical keys for superior tactility and faster response
The Razer BlackWidow's mechanical key technology provides a distinctive tactile feedback in form of a light pronounced tap to your fingers giving you an entirely new feel on your keyboard. With its optimized actuation force of 50 g and a reduced actuation distance of 2 mm the Razer BlackWidow's keys allow you to actuate your commands faster than on any other standard gaming keyboard. -
On-the-fly macro recording and profiles allow effortless configuration
Record unlimited macros on-the-fly without having to take your eye off the game and immediately change between up to 10 profiles without the hassle of going into complex driver menus. With the simple click of two buttons you initiate and end the recording and you're all set. -
Individually backlit keys with 5 levels of lighting
- Razer BlackWidow Ultimate 2013 - keyboard
- Keyboard
- Backlit
- Interface
- USB
- Connectivity Technology
- Wired
- Hot Keys Qty
- 5
- Hot Keys Function
- Multimedia, programmable, macros buttons
- Integrated USB Hub, profiles support, On-The-Fly macro recording, braided cable
- 47.5 cm x 17.1 cm x 3 cm
- 1.5 kg
- 1-year warranty
- Keyboard
- Backlit
- Interface
- USB
Input Device
- Hot Keys Qty
- 5
- Hot Keys Function
- Keyboard Technology
- Mechanical
- Anti-ghosting
- 47.5 cm
- 17.1 cm
- 3 cm
- 1.5 kg
- Headphone output , Microphone input
- Cables Included
- 1 x USB cable
- OS Required
- Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 - 10.6
- Limited warranty - 1 year
