Razer Abyssus Gaming Mouse - infrared - 3 button(s) - wired - USB
Quicklinx: 81NKWS00 Mfr#: RZ01-00360100-R3G1
The Razer Abyssus is created for gamers looking for quality, reliability and performance in a no-nonsense, straightforward gaming-grade mouse. Designed to focus on the fundamentals of competitive gaming, the Razer Abyssus is armed with ultra-responsive buttons tuned for maximum tactile feedback. With an uncompromising 3500dpi Razer Precision 3.5G infrared sensor at its core, take full control of your every aim with perfect tracking so you outgun your competition.
3500dpi Razer Precision™ 3.5G Infrared Sensor
Whether you are making small, precise movements or fast, long range swipes; The Razer Abyssus keeps up with your every movement without tracking loss. With no drift control, experience true freedom of movement that allows your exact mousing movements to be translated into in game kills.
3 Buttons Tuned For Ultra-Responsive Feedback
The Razer Abyssus features large tactile buttons tuned for rapid clicking that responds to your commands with instant response - so you are always a gunshot or spell ahead of your enemies.
Hardware Toggles for DPI and Polling Rate
Adapt to your game instantly with 2 toggle switches for 450/1800/3500dpi and 125/1000Hz polling rate adjustments without the need for any software drivers.
  • Razer Precision 3.5G infrared sensor
    Whether you are making small, precise movements or fast, long range swipes; the Razer Abyssus keeps up with your every movement without tracking loss. With no drift control, experience true freedom of movement that allows your exact mousing movements to be translated into in game kills.
  • 3 buttons tuned for ultra-responsive feedback
    The Razer Abyssus features large tactile buttons tuned for rapid clicking that responds to your command with instant response - so you are always a gunshot or spell ahead of your enemies.
Razer Abyssus - mouse - USB
Mouse
Wired - USB
Orientation
Right and left-handed
6.3 cm x 11.5 cm x 4 cm
Movement Detection Technology
Infrared
Buttons Qty
3
Movement Resolution
3500 dpi
Performance
1 ms response time, 15 G maximum acceleration
Programmable buttons, scrolling wheel
1 x USB cable - integrated - 2.1 m
Microsoft Windows XP, Microsoft Windows 7
Microsoft Certification
Compatible with Windows 7
Mouse
Orientation
6.3 cm
11.5 cm
4 cm
Input Device
Wired
USB
Infrared
Buttons Qty
3
Movement Resolution
3500 dpi
Performance
1 x USB - 4 pin USB Type A
System Requirements Details
HD 35 MB
