Qsan Technology U110 4 Bay 8TB SE 1u ZFS NAS/iSCSI
Quicklinx: 98LVWS00 Mfr#: U110/8TB-SE
  • Atom
TrioNAS features thin provisioning to allocate disk storage space in a flexible manner based on the minimum space required. With all the green designs, TrioNAS U110 helps organizations to save resources and money.
TrioNAS U110 is designed to addresses the explosion of unstructured data and files, where reads/writes are random, by treating random writes as sequential blocks. To provide better file data sharing, the ZFS-based storage system supports SMB v2.0, NFS v3/v4, AFP v3.3, FTP and SFTP, WebDAV, and iSCSI CHAP. In addition, TrioNAS U110 offers very easy-to-use management tools including QCentral, SNMP trap, performance states, and start-up wizard and so on. All these functions allow SMBs and work groups to manage TrioNAS U110 at minimum efforts and greatly enhance the efficiency in the working environment.
TrioNAS U110 adopts Intel Atom CPU and provides high availability. With cost-effective platforms it adopts, TrioNAS offers the same functions to SMBs and workgroups at a much better price. At the same price, TrioNAS U110 provides more superb enterprise-level features; providing the same feature, TrioNAS U110 offers the best values to customers.
Integration NAS and iSCSI SAN, TrioNAS U110 unified architecture help customers to solve many data management problems with a single system, making complex and fast growing storage needs much more manageable and affordable.
  • ZFS file system
    To provide better data integrity, TrioNAS U110 adopts ZFS file system that employs copy-on-write transactional semantics to validate data stored under its protection to avoid data inconsistencies. The self-healing architecture enables the system to detect silent data corruption and correct error on the fly. In addition, users no longer need to predetermine the size of a file system since it grow automatically within the disk space allocated to the pool to save storage capacity. If the storage pool becomes overcrowded, user can even grow it on a live TrioNAS U110 system.
  • Thin provisioning
    TrioNAS U110 delivers thin provisioning to provide more physical resources than actually available capacity so that organizations can avoid allocated but unused storage and be able to purchase only the disk capacity they actually need. Therefore, thin provisioning feature can significantly raise storage utilization and help enterprises to save cost.
  • Compression
    Data compression can also help users to better utilize the resources. With data compression, the size of data stored in TrioNAS can be greatly reduced to save storage capacity.
  • Advanced data protection
    To keep data safe, TrioNAS offers numerous advanced data protection features including snapshot, volume clone, file system clone, remote replication as well as 3-year free McAfee antivirus protection.
  • Multiple protocol supports
    TrioNAS U110 supports SMB v2.0 and NFS v3/v4 for Unicode files. It also supports AFP v3.3, FTP, SFTP, WebDAV and iSCSI CHAP that is always an integration headache on Linux system.
  • Easy to manage
    TrioNAS U110 can be centrally managed by QCentral the java-based cross-platform management interface. In addition, TrioNAS U110 also features online firmware upgrade, event notification via email and SNMP, performance states, system monitoring, MAID and S.M.A.R.T. supports, start-up wizard, wake-on-LAN and web UI.
  • UnifiedAUTH
    The UnifiedAUTH technology is that any OS client (Windows, Linux, Mac, FTP, and WebDAV) and iSCSI CHAP can log onto the TrioNAS LX device through Microsoft Active Directory. With UnifiedAUTH, IT administrators can just manage employees' accounts by Windows AD or LDAP, while end-users can easily use their Windows AD/LDAP ID and password to login via clients of any popular OS.
Qsan TrioNAS U110 - NAS server - 8 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
8 TB
4 (installed) / 4 (max)
44.2 cm x 71.12 cm x 4.4 cm
1 x Intel Atom D2550
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 10
Hard Drive
4 x 2 TB SATA 6Gb/s
Network adapter 10Mb LAN, 100Mb LAN, GigE
RAM
4 GB
SunSoft Solaris, Apple MacOS, Red Hat Linux 5.0, Red Hat Linux 6.0 or later, Microsoft Windows
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
8 TB
44.2 cm
71.12 cm
4.4 cm
Processor / Memory
Processors Installed
Max Supported Qty
1
RAM
4 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Hard Drive
HDD - hot-swap
4 x 2 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Network adapter
Network / Transport Protocol
NTP, iSCSI, FTP, DHCP
Remote Management Protocol
SNMP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DHCP, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
DHCP support, trunking, LDAP support, VLAN support, wake on LAN (WOL), antivirus analysis, Jumbo Frames support
Encryption Algorithm
SSL, TLS
IEEE 802.3ad (LACP)
Expansion Bays
4 (total) / 0 (free) x hot-swap
2 x Ethernet 1000Base-T - RJ-45
UL, BSMI, cUL, CB, FCC, RoHS
Internal power supply
Installed Qty
1
Power Provided
130 Watt
Limited warranty - 3 years
5 - 95% (non-condensing)
